Old 01-02-2020, 10:17 PM   #1
Stomachbuzz
Drives: 2013 FRS
How to cure silicone coating for exhaust wrap?
Wrapped my header. Wasn't initially intending to coat it with the hi-temp silicone, but the instructions heavily recommended it, so I bought a can.
I got the DEI brand. The instructions say to cure the sprayed object at 400F minimum.
Obviously my oven can heat to 400F, but my header won't fit in there, nor would I want this type of chemical curing in there.
What is the recommended way to cure with respect to exhaust wrap? Can I spray it, and then assume it will cure when the header is on the car? Might not reach 400F without a cat
Stomachbuzz is offline   Reply With Quote
Old 01-02-2020, 11:04 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
BRAP.P.P.P.P.P.P.P.P.P.P.P.P.
Old 01-02-2020, 11:53 PM   #3
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
You could always purchase a super cheap used stove and use it. then sell or trash it. Or possibly find a place which does curing and ask to use their facilities.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Stomachbuzz (01-03-2020)
Old 01-03-2020, 12:07 AM   #4
Stomachbuzz
Drives: 2013 FRS
I dug through their website some more and found it hidden away in the FAQ section that you can cure it by putting it on the car.
Probably should have put that in the initial instructions.
Old 01-03-2020, 12:30 AM   #5
86MLR
86MLR's Avatar
Go for a drive
Your exhaust will be around 400° F (200° C) driving around , and alot hotter if you start giving it some beans.
The Following User Says Thank You to 86MLR For This Useful Post:
Clutch Dog (01-07-2020)
Old 01-06-2020, 03:37 PM   #6
Stomachbuzz
Drives: 2013 FRS
Ended up going for the "cure on the car" method.
Was definitely prepared for a decent amount of smoke and some bad fumes. That's what I got!
Still throwing off some nauseous smells (noticeable when stopped) even after 20 minutes of highway driving. Yuck! I guess the solution is just to keep movin'
Old 01-06-2020, 03:37 PM   #7
Stomachbuzz
Drives: 2013 FRS
Old 01-06-2020, 04:19 PM   #8
tomm.brz
Drives: brz 2017 hksv2
around the lambda, it will easily reach 600°C in few minutes, and that s just by idling during coldstart and drive lowspeed
i would assume the whole metal header will reach at least 400-450 C, since the wrap itself will help contain the heat
edit: sorry, didn t read well that you already did..
good then
Old 01-06-2020, 04:26 PM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I love the smell of toasting heat wrap! For a week people kept asking me why I smelled funny at work.
Old 01-07-2020, 01:11 AM   #10
gpvecchi
gpvecchi's Avatar
Yep, it smells like hot dogs.
Thermal Barrier Coating Ceramic Coating for Exhaust and More Dadajair Southern California 2 03-25-2019 10:09 PM
GTA high temperature silicone coating FLYFISHR CANADA 4 12-28-2017 08:20 PM
HPS silicone intake elbow and JDM exhaust tips Mr.Scion Engine, Exhaust, Bolt-Ons 8 10-02-2014 06:18 PM
Drop in, silicone tube, exhaust, NO tune...problems? BlackyRose Engine, Exhaust, Transmission 19 07-06-2013 12:57 PM
