Old 10-25-2019, 12:10 PM   #1
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
Trouble Downshifting into 5th
Hey Guys,
I've been having this issue lately and I wanted to get your opinion. I'm having trouble down shifting from 6th to 5th. If I try to do it in one motion it like locks me out and I cant get it into 5th. If I go over to neutral and wiggle it around a bit then I can pop it into 5th just fine. Up shifting from 4th to 5th is fine as well.
This was not an issue before and it just recently started happening, probably worth mentioning it has started getting colder here in MN. Car is a 2017 with 25k miles; shifter springs, whiteline trans bushing, perrin shifter bushing, fx400 clutch, mt-90 trans fluid 3k miles ago. Was working just fine with all these mods before so not sure they're the cause.
Could it just be the cold weather? Anything I can do to fix this?
Thanks in advance
MotoX16 is offline   Reply With Quote
Old 10-25-2019, 01:08 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
cold weather is certainly biggest factor but I don't agree with changing the trans fluid in general and especially before 100 K..who knows if your new fluid is less viscous in colder temps than the previous stuff..
do you notice it become easier to shift after it warms up?
HKz is offline   Reply With Quote
Old 10-25-2019, 01:37 PM   #3
MotoX16
MotoX16's Avatar
Well the only reason I changed my trans fluid is because I replaced my clutch. And I read MT-90 was pretty good stuff.
But no the problem still persists even after the car is fully warmed up
Old 10-25-2019, 02:27 PM   #4
xdavidx
Emperor McDuck
xdavidx's Avatar
Drives: 2019 86 GT; 2018 BMW S1000RR
Originally Posted by MotoX16 View Post
Hey Guys,
Thanks in advance
Simple fix, don't downshift to 5th. Not much purpose for it anyway... if you are downshifting to pass you probably need more power than 5th and if you are downshifting to go slower 4th is a perfectly fine option.
That... or you could bring it to the dealer since it appears to be within the warranty period and have them fix it because there is no reason a car won't be going into gear during normal driving that doesn't mean there is something wrong.
Instagram: @s1kmotodragon
YouTube: S1KMotoDragon
xdavidx is offline   Reply With Quote
Old 10-25-2019, 02:54 PM   #5
MotoX16
MotoX16's Avatar
I use 5th all the time, most of my commute is in that 50-60mph range. So thats a no go on the simple fix.
I have a hard time believing the dealer would fix anything under warranty. Boosted with an aftermarket clutch will probably get me shot down, but it might be worth a try.
Old 10-25-2019, 03:02 PM   #6
xdavidx
Emperor McDuck
xdavidx's Avatar
I will take back my cynicism and snarky comment. I see lots of people post things they are perplexed by how to fix when they are under warranty and can just bring it back to the dealer, have a cup of coffee, and drive home trouble free. In your instance, I can see that may not work out so well. If you have a cool dealer they 'should' cover it because it really isn't related, but I can definitely see most dealers using it as an excuse not to do the work.
Old 10-25-2019, 03:17 PM   #7
Bubba suggests you bleed the clutch system. Then, don't lazy leg the clutch pedal and blip the throttle at the "right" time.
humfrz for Bubba
Old 10-25-2019, 05:00 PM   #8
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
when you replaced your clutch, did you replace your throwout bearing? if yes, what throwout bearing did you use? Did you grease it? if yes, what did you grease it with?
pgranberg11 is offline   Reply With Quote
Old 10-25-2019, 06:02 PM   #9
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
01. Rev match your shift
that will work but if that proves too tricky try
02. Double clutch
Did you break in your clutch properly after the install? With a new clutch there is a break in process before you can expect to drive normally.
DandoX is offline   Reply With Quote
Old 10-25-2019, 07:49 PM   #10
There is no magical relationship between fifth gear and the clutch. A dragging clutch will make it difficult or impossible to engage any gear in either upshifting or downshifting.
Is this really only felt downshifting and only into fifth?
ermax (10-26-2019)
Old 10-25-2019, 10:24 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
are you rev-matching?
Old 10-26-2019, 02:17 AM   #12
I believe the TOB on these cars come pre-lubricated. Now, the clutch fork may need a dab of lubricant -
Old 10-26-2019, 03:00 AM   #13
ermax
ermax's Avatar
I mostly agree but it could be dragging just enough to cause issues in the higher gears with less synchros yet still feel fine in lower gears with triple cones. I would suggest jacking the rears off the ground and verify that the wheels aren’t creeping when the clutch is fully pressed just to rule that out.
Oh and do a long press of the TC button before doing this test or the ABS will go crazy on the rear wheels if the wheels do turn at all.
The Following User Says Thank You to ermax For This Useful Post:
Ultramaroon (10-26-2019)
Old 10-28-2019, 10:47 AM   #14
MotoX16
MotoX16's Avatar
Yes I replaced the throwout bearing with a 2017 one, with the white dot. Not exactly sure what grease I used, think it was some high temp wheel bearing grease I had laying around
Starts and Downshifting DauntlessFRS Scion FR-S / Toyota 86 GT86 General Forum 68 09-12-2017 01:45 PM
Downshifting problem from 5th to 4th n0thing Issues | Warranty | Recalls / TSB 16 01-18-2017 08:57 AM
Trouble downshifting to 2nd MT kEnYUnoT Issues | Warranty | Recalls / TSB 4 11-12-2015 06:59 AM
Downshifting jaime3 Scion FR-S / Toyota 86 GT86 General Forum 18 07-24-2013 09:09 PM
Downshifting AT Estey Engine, Exhaust, Transmission 20 11-14-2012 01:20 PM
