Old 10-08-2019, 03:41 PM   #1
pevsfreedom
Drives: 2014 BRZ
New engine is in - some issues
As to be expected I guess there's some new issues with my new (stock replacement) engine being tossed in (old one threw a rod);
It dies in idle quite often and is rackety as all hell. Once it gets going it's fine. Some smoke from the passenger side near the fuse box on occasion.
Here's preliminary codes from Autozone, which says to replace ignition coils but I don't know about that.
It repeats after the first 7 -
I mean I guess it's kind of self explanatory, but I'm looking for any notes/advice because this is all new to me (first engine swap.. or ever touching an engine):
pevsfreedom is offline   Reply With Quote
Old 10-08-2019, 03:52 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
first time touching an engine ever...? you mean to say you've yet to make love with your engine??
who replaced the engine and why aren't you going back to them? even if we could diagnose it over the webz, not sure what an engine virgin would even do with such info..
HKz is offline   Reply With Quote
Old 10-08-2019, 03:56 PM   #3
pevsfreedom
Drives: 2014 BRZ
I replaced the engine with a friend who has some experience. An engine virgin would probably take the info and use it in a helpful manner, assuming it was helpful. The biggest problem I think is that 1/2 the shit on the "new" (~15k) mile engine was bad.
The Following 2 Users Say Thank You to pevsfreedom For This Useful Post:
HKz (10-08-2019), mrg666 (10-08-2019)
Old 10-08-2019, 04:00 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Is this a brand new engine? Completely? or just a short block and you swapped your existing hardware onto it?
Have you double checked to be sure the direct injection ECU is completely secured? The frame acts as a ground for the direct injection ECU.
I'm not trying to be discouraging, but if you're unable to troubleshoot a misfire, was it wise to try assembling and putting in an entire engine with no prior experience? I definitely would advise taking it to a reputable shop ( not auto zone) to have it seriously diagnosed and resolved by technicians.
Best of luck regardless, hopefully it is something you can resolve on your own and learn from!
Old 10-08-2019, 04:05 PM   #5
pevsfreedom
Drives: 2014 BRZ
Longblock, was supposed to be all stock with 15-20k miles - it had lots of broken parts and weird little mods unfortunately and we ended up swapping a lot. I don't have money to get it professionally done yet - and no it probably wasn't wise, but hey sometimes you gotta give things a try. Today's the first day of troubleshooting so I'm not discouraged yet. And I have learned a lot. My old engine had 50k miles and threw a rod so I really wasn't expecting this massive financial burden as the car is only 5 years old with hardly any miles Autozone was only to get the codes - wasn't planning on them fixing anything, lol.
I mean I guess my plan is to go down the list and swap off parts and diagnose what I can. When it's beyond my paygrade I'll bring it in if I have to. But for now I'm determined to try and fix it myself.
Old 10-08-2019, 04:08 PM   #6
fika84
fika84's Avatar
The over-advance code might indicate a timing chain out of alignment (IE - jumped some teeth). Or a bad cam sensor.
fika84 is offline   Reply With Quote
Old 10-08-2019, 04:11 PM   #7
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
How does it smell?
mrha is offline   Reply With Quote
Old 10-08-2019, 04:14 PM   #8
pevsfreedom
Drives: 2014 BRZ
Originally Posted by mrha View Post
How does it smell?
Well after the first 20 minutes of smoke blowing out it's ass from the old engine blowing all the oil into the exhaust it doesn't smell bad. A tiny bit of smoke/oil smell. Hard to tell if it's any type of residue still.
Old 10-08-2019, 04:17 PM   #9
pevsfreedom
Drives: 2014 BRZ
It also shows the ABS light and the VSC and traction control buttons don't do anything.
Old 10-08-2019, 04:19 PM   #10
DarkPira7e
DarkPira7e's Avatar
What year was the longblock from? I would try swapping the coils over from your old engine if you still have them. Any parts that were known working well should be on this new engine to troubleshoot this. I admire and understand your willingness to take this on. I think quite a few of us have been in a position like that.
Let's hope as a team we can come out on top and save you some $ then. If not, I'd save up for a beater until you can make it right here.
mrg666 (10-08-2019)
Old 10-08-2019, 04:26 PM   #11
It is ambitious! I am a bit nervous for him considering that the engine he got was already pretty modified and nobody could figure out why.
https://www.ft86club.com/forums/showthread.php?t=137119
Who know what has been done to the vacuum system and possibly even the timing.
DarkPira7e (10-08-2019), HKz (10-08-2019)
Old 10-08-2019, 04:28 PM   #12
When you get a serious CEL the ECU puts the car into what is called "limp mode". The lights on and things not working is part of that mode. Bet you have no cruise either. You will need to resolve and clear the code to get full function back.
Old 10-08-2019, 04:41 PM   #13
DarkPira7e
DarkPira7e's Avatar
I didn't even realize it was THAT engine. I remember seeing the thread and not wanting to poke my nose in because I had no idea what was going on.
Old 10-08-2019, 04:46 PM   #14
pevsfreedom
Drives: 2014 BRZ
So I puled the negative terminal to try and reset the light and it dropped 3 errors at the time of testing, so down to 4: cyl 4 misfire, random misfire, ignition coil, bank 1 air fuel ratio imbalance.
Lol it's from the same exact make/model but the guy says its a JDM engine which I couldn't exactly find any info on - but yeah I'm THAT guy Supposed to be stock. The "limp mode" is interesting, I'll try the cruise control. Next step I suppose is like DarkPira7e said and I'll just pull sensors/coils, which I have a good feeling about. I really do appreciate the help! The damn car was a month out of warranty when it blew, but it was a bit of a lemon since I got it.
The Following User Says Thank You to pevsfreedom For This Useful Post:
Tcoat (10-08-2019)
Engine / Tune Issues 1Botnet Engine, Exhaust, Transmission 4 09-05-2018 05:10 PM
Any issues installing FA20 Auto Engine into Manual Car jamison884 Engine, Exhaust, Transmission 1 10-16-2017 09:21 AM
Is this engine or tranny issues? 86Hiro Engine, Exhaust, Transmission 9 09-23-2015 02:51 PM
Toyota FTS report engine issues with FR-S running 91 octane DYOLF26 Issues | Warranty | Recalls / TSB 24 08-06-2012 01:22 PM
Any issues with Subaru engine? CyberFormula Engine, Exhaust, Transmission 10 06-26-2010 05:02 PM
