Old 05-25-2019, 09:40 AM   #1
Windycitystig
Drives:
Manual transmission fluid flush vs drain and fill
There are two ways to service manual transmission fluid.
The first is to use a transmission fluid exchanger machine to flush the fluid. This is themore expensive of the two options.
The second is to drain the fluid and then add in new fluid.
Does it make a difference which method you use to maintain the warranty?
Windycitystig is offline   Reply With Quote
Old 05-25-2019, 10:18 AM   #2
No
Old 05-25-2019, 12:00 PM   #3
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The warranty expires before the first recommended trans or diff fluid change?
Old 05-25-2019, 08:56 PM   #4
86MLR
86MLR's Avatar
Same as engine oil, drain it when it's hot.
Old 05-25-2019, 09:05 PM   #5
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Just pull the fill plug first.
The Following User Says Thank You to Spuds For This Useful Post:
86MLR (05-26-2019)
Old 05-25-2019, 09:08 PM   #6
R32Gaijin
Drives: 2019 BRZ
Just drain and fill. “Flushing” only makes sense in automatic transmissions, where to replace the fluid, it needs to be running. But our manual transmissions are an empty case with spinny dudes in it that when at operating temp, drain to the bottom of the pan fairly quickly.
R32Gaijin is offline   Reply With Quote
The Following User Says Thank You to R32Gaijin For This Useful Post:
jcw99 (05-26-2019)
Old 05-27-2019, 04:05 PM   #7
computeruser
Drives: 2015 BRZ
Not if you just change it yearly as a matter of course!
computeruser is offline   Reply With Quote
Manual Transmission + Differential Drain Bolt Crush Washers skylinekin Transmission and Driveline 0 12-27-2017 04:22 PM
Any UOA for manual transmission fluid? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 09-05-2017 11:41 AM
Is it necessary to completely flush automatic transmission fluid? lupindub Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 05-30-2016 02:47 PM
Manual Transmission Fluid, GL-3 vs. GL-4 ducky106 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 11-10-2015 06:40 PM
Transmission fill and drain plugs goshem Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 07-27-2014 12:37 AM
