Old 06-28-2018, 10:10 AM   #1
jRuN
New red aluminum intake manifold fit 2015?
Hello!
New BRZ owner here, just curious if I can purchase the new red aluminum intake manifold from the new model BRZ and if it is a direct bolt on replacement on my 2015? Has anyone done this? Are there any additional requirements to do the swap?
I'll admit, on the surface, I am looking to do it because it looks so damn good in the engine bay on the WRB Brz.. but I plan to go FI in the future and would like the new intake manifold to go along with that. I've heard while you got the intake manifold off there are some vacuum lines underneath it that should be clamped on that don't already have clamps for when you go boosted.. figured i'd take care of that in the process as well.
jRuN is offline   Reply With Quote
Old 06-28-2018, 11:17 AM   #2
PuslarBrrrz
It fits no problem, just get all your gaskets and you are good to go.
PuslarBrrrz is offline   Reply With Quote
Old 06-28-2018, 11:38 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
It's on expensive side though. As there will be close to no performance gains .. i'd rather spend that money elsewhere. Too expensive for just looks of part you won't see most of a time imho.
Old 06-30-2018, 10:03 PM   #4
makinen
makinen's Avatar
Drives: Toyota 86
DI Injector covers need to be modified or you need to get MY17 covers. Another option is Verus ones.
The biggest difference you may notice is NVH. Engine noise will be quieter.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 06-30-2018, 11:14 PM   #5
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
You just need the ecu bracket rail cover, you don’t need the drivers side. The DI punp might be a bit louder without it though, there’s a ton of padding on the stock one
Jrdad is offline   Reply With Quote
Old 07-01-2018, 09:21 AM   #6
Ernest72
Take your black one off, clean, prep and paint red. Way cheaper than 400 bucks. I just sprayed my 04 WRX intake black - looks great.
2013 intake manifold vs 2017 Aluminium intake manifold Bobster Engine, Exhaust, Transmission 29 12-19-2016 10:40 AM
2017 Aluminum Manifold F/I Gearbanger Forced Induction 11 11-14-2016 05:56 PM
Cusco Aluminum Pulley Set Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 RallySport Direct Engine, Exhaust, Bolt-Ons 0 06-09-2015 01:05 PM
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 01:43 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
