Old 12-27-2017, 09:20 PM   #1
darkbluemn
Drives: Brz
Is it OK to raise engine a little bit on passenger side using washers?
I had issue with header rubbing the skid plate. I raised the engine a little bit using high grade washers on passenger side to solve the problem. It's about 2-3 mm. Is there any problem with this DIY?
Thanks.
darkbluemn is offline   Reply With Quote
Old 12-27-2017, 09:26 PM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Probably be a better idea to clearance or space the skid plate.....and easier...
The Following User Says Thank You to Summerwolf For This Useful Post:
Qadthane (12-29-2017)
Old 12-27-2017, 09:28 PM   #3
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
You would be better off taking the skid plate and pounding the part that's rubbing with a hammer, and/or getting stiffer engine mounts. This was a known issue with Ace headers and there is a guide to fix it.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
The Following User Says Thank You to Spawn_Of_Creation For This Useful Post:
Grady (12-28-2017)
Old 12-27-2017, 09:29 PM   #4
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Use a dremel and cut that small section of the skid plate off
Dr. BRZ is offline   Reply With Quote
Old 12-27-2017, 09:31 PM   #5
Yes. Your DIY gave me cancer.* Why fuck up the geometry of the drive line to address an interference problem with an aftermarket part?
Tweak the skid plate, not the rest of the car.
*It's probably fine.
The Following 14 Users Say Thank You to Ultramaroon For This Useful Post:
asdf (12-28-2017), bcj (12-27-2017), chaoskaze (12-30-2017), Decep (12-28-2017), fika84 (12-29-2017), gtengr (01-01-2018), humfrz (12-27-2017), JD001 (12-28-2017), JoeC (01-03-2018), Leonardo (12-28-2017), thecarfilmer (01-03-2018), Wes (01-01-2018), wparsons (01-10-2018), Zentec (01-01-2018)
Old 12-27-2017, 09:53 PM   #6
Thanks.
Hello darkbluemn and welcome to our forum .......
Welp, there went your warranty ......
(jest ah messen wich ya)
I checked with Bubba and he just rolled his eyes and mumbled something about that's what crowbars are for ......
The Following 3 Users Say Thank You to humfrz For This Useful Post:
bcj (12-27-2017), Ultramaroon (12-27-2017), Zentec (01-01-2018)
Old 12-28-2017, 12:06 AM   #7
FRS Justin
Drives: 2013 Asphalt FRS
or just buy a set of good motor mounts that don't flex
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-28-2017, 03:21 AM   #8
NRXRaptor
If I am able to install whiteline kits KTD 922, 925, and 926, would I be able to install engine mounts as well? I had to use almost all my consternation to do it but I did it
NRXRaptor is offline   Reply With Quote
Old 12-28-2017, 05:02 AM   #9
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
bash your header. It's an old time fix and doesn't effect power output at all.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Ultramaroon (12-28-2017)
Old 12-28-2017, 07:25 AM   #10
Grady
Grady's Avatar
This is the right answer!
Old 12-28-2017, 12:40 PM   #11
gtengr
Drives: 2017 BRZ
It was an easy job while changing out the header. Leaving the header in place makes it more challenging. I used the sti mounts and think they're perfect for a street car.
gtengr is offline   Reply With Quote
Old 12-28-2017, 01:16 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
2-3 mm of washers and you fixed your problem? An elegant solution.
Old 12-28-2017, 01:28 PM   #13
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I just LOL'd at my desk.
I LIKE TIRES!
Old 12-28-2017, 03:06 PM   #14
If I let go of my obsessive emotional attachments, it really is.
WTB: 1 OEM STI Side Skirt (passenger side) x1UP Want-To-Buy Requests 4 09-12-2017 12:54 PM
WTB: passenger side amber side marker NJ-JDM Want-To-Buy Requests 4 05-18-2016 05:37 PM
WTB: Passenger Side Clear Side Marker Sheepdog Want-To-Buy Requests 0 08-03-2015 08:56 PM
WTB: Drivers side and passenger side fenders condition don't matter Hollwood_lives Canada Classifieds 5 07-30-2015 04:53 PM
WTB: orange OEM side marker (passenger side or both) Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 4 09-05-2013 04:46 AM
