Old 02-25-2017, 09:49 PM   #1
dutchman1
Drives: 2017 86 6-Speed
Koni Yellow Rebound Settings
My car will be used quite a lot for autocross this year and am wondering what a good base line is for the rebound settings with the stock (non-TRD) springs.
I'm quite aware of what adjusting the front/rear shock rebound does in terms of fine tuning the handling, but not sure where the proper baseline is.
I'm guessing it is quite close to full soft with the OEM springs, seeing as most of the guys I've seen are running .5-1.5 from soft on the stiffer TRD springs.
Anyone have any idea where they should be at for proper dampening?
dutchman1 is offline   Reply With Quote
Old 02-25-2017, 11:20 PM   #2
ryoma
ryoma's Avatar
set it at the softest and go from there. it will take some fine tuning since your driving style will be different than someone else's. what works for someone else might not work for you, even if they have the exact mods.
The Following User Says Thank You to ryoma For This Useful Post:
dutchman1 (02-26-2017)
Old 02-26-2017, 10:03 AM   #3
freerunner
freerunner's Avatar
Drives: GT86
To increase understeer/stability at corner-entry, increase rear rebound*
To increase oversteer/agility at corner-exit, increase front rebound*
And vice versa.
It's really more complicated than that (one thing here affects another thing there), but it's basically what these settings do.
*) for low-speed damper settings (not vehicle speed!)
freerunner is offline   Reply With Quote
Koni Yellow inserts rebound information Aztec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-24-2015 08:56 PM
Fortune auto 500 coilovers vs. RCE Yellow springs + KONI Yellow shocks Kyogre Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 05-12-2015 04:59 PM
WTB: Koni yellow struts and RCE yellow springs nlowell Brakes, Suspension, Chassis 2 05-20-2014 03:10 PM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 10:32 AM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 12:10 PM
