Old 01-28-2016, 10:36 PM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile OFT350 (SBD/ZAGE) on E85 Dyno results
342whp at 12psi
320whp at 10psi
More details here: https://www.facebook.com/OpenFlash-P...3431676670350/
Next step... flex fuel
Shiv@Openflash is offline   Reply With Quote
The Following 9 Users Say Thank You to Shiv@Openflash For This Useful Post:
DustinS (01-29-2016), D_Thissen (01-28-2016), FirestormFlex (01-29-2016), hmong337 (02-05-2016), JonAvalon (01-28-2016), MisterSheep (01-29-2016), NyC Zn6 (01-29-2016), Teseo (01-28-2016), trigger happy (02-01-2017)
Old 01-28-2016, 10:40 PM   #2
bleox
Drives: 2015 Subaru brz
Flex fuel would be amazing
bleox is offline   Reply With Quote
Old 01-28-2016, 10:41 PM   #3
D_Thissen
D_Thissen's Avatar
Stock block? Sorry if that's been answered a million times.
Old 01-28-2016, 10:59 PM   #4
Shiv@Openflash
Drives: 2013 FRS
Yes, stock block. 100% stock fuel system. Even running the original spark plugs (20k miles).
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
D_Thissen (01-29-2016), hmong337 (02-05-2016)
Old 01-29-2016, 12:20 AM   #5
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
I am assuming tuned with the OFT?
drew_kar is offline   Reply With Quote
Old 01-29-2016, 12:35 AM   #6
Shiv@Openflash
Drives: 2013 FRS
Yes of course!
Old 01-29-2016, 01:20 AM   #7
bleox
How close is flex fuel
Sent from my Nexus 6 using Tapatalk
Old 01-29-2016, 07:55 AM   #8
gl2filmerguy
gl2filmerguy's Avatar
Drives: 2013 Ultramarine FR-S
This is amazing. Thank you Shiv@Openflash!!!
gl2filmerguy is offline   Reply With Quote
Old 01-29-2016, 08:17 AM   #9
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Why was the 340whp pull not taken to redline?
NotSoJDM is offline   Reply With Quote
Old 01-29-2016, 08:59 AM   #10
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
When can we expect to get e85 tune for SBD kit?
The Following User Says Thank You to NyC Zn6 For This Useful Post:
Old 01-29-2016, 09:46 AM   #11
ST-A
Master Tuner
Drives: GT86 + Celica ST205 GT-4 WRC + MR2
Nice results shiv, kind off the same results i'm expecting with the kraftwerks +OFT, but we needed upgraded injectors
i'm interested to see the cam timing maps, as that is what we are still testing to keep more pressure in the block instead of straight out of the exhaust .
ST-A is offline   Reply With Quote
Old 01-29-2016, 10:54 AM   #12
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
How hard are you leaning on the DI system here to achieve this? Virtually every other tuner I've talked to says above 300whp or so on E85, you really need upgraded port injectors to keep your DI injection time in the correct window for optimum function.
You are quite above that here.
xsnapshot is offline   Reply With Quote
The Following User Says Thank You to xsnapshot For This Useful Post:
Old 01-29-2016, 10:56 AM   #13
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Nice job shiv! in for any updates you may have! Makes me want to pick up a SBD kit
Instagram: trevor.parque
Old 01-29-2016, 11:12 AM   #14
NyC Zn6
NyC Zn6's Avatar
same same
Australian Dyno Dyno Results Shiv@Openflash Software Tuning 11 07-22-2015 04:57 AM
Nate's SBD/ZAGE Turbo Kit (DYNO Tune) by Bill@Delicious Tuning 2013GTRNate Forced Induction 38 05-29-2015 03:15 PM
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
AT/MT Dyno Results with/without Mods blackfireball5 Engine, Exhaust, Transmission 0 07-04-2012 02:34 PM
