Old 01-30-2015, 08:33 PM   #1
xuimod
Drives: 2007 MX-5 Miata, 2015 VW Golf GTI
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion?
I'm seriously thinking about adding FI into my FR-S and am looking closely at Greddy Turbo kits.
But I was reading this post here and this poster said under constant, heavy usage, Greddy Turbo's have the tendency to melt stock radiator fans (see image below). He said this might be due to the wiring of the fan being close to the Turbo manifold.
So to all Greddy Turbo owners (or Speed By Design/Zage Turbos since they're so similar), have you experienced anything like this? Also, in general what is your opinion of those kits and how many miles have you had the kits installed?
xuimod is offline   Reply With Quote
Old 01-30-2015, 08:44 PM   #2
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
i understand that this fan was burned in this pick was because the greddy owner overspooled the turbo.
i would get the sbd its cheaper and you get the same performance or around there
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 01-30-2015, 10:59 PM   #3
mrk1
Drives: Sterling BRZ Ltd
over spooled? is that a thing?
Just about any turbo kit will benefit from some slim fans. I do believe this is a example of one photo making rounds and is not a good example of what most people experience.
I have installed a handful of SBD kits and am not a fan, missing parts, low quality.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-31-2015, 10:38 AM   #4
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
full blown motorsports offer a dual spal slim fan setup to help with this. you can also make brackets to move the radiator forward a few inches. Lasstly a good ceramic coating, heatwrap and turbo blanket will help keep the hot parts hot and cold cold.
Old 01-31-2015, 11:32 AM   #5
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
I run the greddy Kit and have not melted my fbm cooling system yet and it has been on the track with back to back hot laps. You can always buy thermal wrap for wires if you are worried. 15k miles on the Kit daily driven
Build Thread
Instagram
Old 01-31-2015, 11:44 AM   #6
mrk1
Spencer Fabrication brackets move the radiator forward,
The Build Thread
The Following 3 Users Say Thank You to mrk1 For This Useful Post:
Cessblood (02-12-2015), DustinS (02-02-2015), hmong337 (01-31-2015)
Old 01-31-2015, 12:56 PM   #7
2013GTRNate
2013GTRNate's Avatar
Out of curiosity, are the people reporting the melting of their fan shrouds using turbo blankets? I ordered the PTP "lava blanket" it is supposed to reduce the radiant heat down to 110 F. Basically no difference than an NA engine bay normal temperature.
2013 Nissan GT-R Premium
2014 Subaru BRZ Limited
2014 Forester XT Touring
My BRZ's thread: http://www.ft86club.com/forums/showthread.php?t=47467
2013GTRNate is offline   Reply With Quote
Old 01-31-2015, 01:30 PM   #8
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
I'm patiently holding out to see if greddy redesigns or does anything different with their turbo kits now that they have partnered with garrett turbos. Probably just swapping turbos but they may be addressing the issue, we'll see.
Are you tracking your car or just street use?
cameronjones239 is offline   Reply With Quote
Old 01-31-2015, 03:46 PM   #9
2013GTRNate
I do a limited amount of Auto X, Track, and Drag Strip duty. The car sees mostly DD duties. For what it is worth I doubt that GREDDY will change very much. As you mentioned I can see them revising the actual turbo but as for the heat related issues I doubt that they will change anything.
I went with the SBD/ZAGE kit because the price is right, zero complaints related to quality, heating issues are easily resolved with PTP's LAVA blanket and Wraps. It just seemed like a no brainer.
The Following 2 Users Say Thank You to 2013GTRNate For This Useful Post:
CxG (08-02-2015), sroby (08-17-2020)
Old 01-31-2015, 03:54 PM   #10
SteveIsBored
Drives: 2013 subaru brz
Which ptp blanket did you order and have u been able to verify figment yet
SteveIsBored is offline   Reply With Quote
Old 01-31-2015, 04:01 PM   #11
2013GTRNate
After calling and speaking to PTP directly, I ordered the PTP LAVA blanket for T25/T28 Turbos. You can order the Subaru WRX blanket as well but the fitment and coverage are not as good for the SBD/ZAGE turbo with the internal wastegate. I'll post picks in my build thread very soon.
Old 01-31-2015, 04:06 PM   #12
SteveIsBored
Thanks I love my kit I'm running oft shiv e-tune and couldn't be happier
The Following User Says Thank You to SteveIsBored For This Useful Post:
2013GTRNate (01-31-2015)
Old 02-02-2015, 04:35 PM   #13
myioz86
Drives: gt-86 2013
Same here been running the SBD kit for 3000klm no probs but have wraped every thing including the all wiring .boosting 11 1/2psi and loving the kit all the way. easy install.
myioz86 is offline   Reply With Quote
Old 02-02-2015, 09:13 PM   #14
ztan
Drives: Toyota 86
Are you still on stock injectors at 11.5 psi? Woudn't mind seeing some logs seeing how much PI time you're using at the top end.
I decided to get my pipes ceramic coated in Brisbane - almost ready to install.
ztan is offline   Reply With Quote
Greddy/Trust T518Z Turbo Kit Owners rocketbunny86 Forced Induction 126 05-24-2024 03:02 PM
NEW for 2021: SBD G500X Ball-Bearing Turbo Kit: $2999 spdbydesignchris Forced Induction 2361 04-01-2021 05:53 PM
FS:A Garrett turbo,& a Greddy turbo kit with extra parts. Cessblood Engine, Exhaust, Bolt-Ons 76 02-18-2015 08:47 AM
