Old 04-22-2014, 10:44 PM   #1
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
DIY Request: heated mirror install
Hi everyone,
Looking for a quick DIY on installing heated mirrors - particularly, just wanted to know how the wiring attaches - is it a plug or exposed wiring or wire 'hook' that latches on, etc...
Thanks!
1Cor10:23 is offline   Reply With Quote
Old 04-22-2014, 11:01 PM   #2
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
its a female connector. on the back of mirrors there are two tabs that the wire connector slips onto.
BoxRZ_86 is offline   Reply With Quote
Old 04-22-2014, 11:10 PM   #3
1Cor10:23
1Cor10:23's Avatar
@Sanka86 thanks - are the female connectors the two tabs that stick out?
Old 04-22-2014, 11:16 PM   #4
BoxRZ_86
BoxRZ_86's Avatar
They are two male ends on the mirrors themselves
http://ft86speedfactory.com/rexpeed-...ated-1354.html
Here if you look on ft86speedfactory's site they have a image of the back of a rexpeed heated mirror. Same connections as the factory mirror.
Old 04-22-2014, 11:17 PM   #5
1Cor10:23
1Cor10:23's Avatar
@Sanka86 got it, think I got the picture now. Cheers!
Old 09-06-2014, 08:24 PM   #6
Casper223
Casper223's Avatar
Drives: 2015 UltraMarine, MT, Borla Exhaust
Wondering if the wiring for the heated mirrors is already run to the mirror hood?? If it is I can just change the factory mirror out for a heated mirror. Can anyone answer this question?
Casper223 is offline   Reply With Quote
Old 10-17-2014, 10:13 AM   #7
arvidj
Drives: '93 MR2 Turbo
A little late to answer this but ...
I just took the mirror off the passengers side of my "bought in the United States No Options 2015 FRS" and there is no heated mirror wiring in the mirror head. I did not take the door panel off to see if it was in the door, but I am positive it is not run up to the mirror head ... i.e. certainly not an easy plug-n-play.
Arvid
Red '93 MR2 Turbo, daily driver, 129,000 miles
Red '93 MR2 Turbo, garage queen, 24,683 miles
Red '15 FRS Automatic, TRD Springs, Swaybars, Brake Pads
arvidj is offline   Reply With Quote
Old 10-21-2014, 03:25 PM   #8
nadbrz
Learnin a little everyday
Drives: '13 Crystal Black Silica BRZ
Is there a DIY showing how to wire heated mirorrs on a non-heated model.
nadbrz is offline   Reply With Quote
Old 12-23-2014, 04:35 PM   #9
morphius88
R0GUE
morphius88's Avatar
Drives: 2013 Whiteout Scion FR-S
I too want to add heated mirrors but there doesnt seem enough interest.
The monogram series has the heated mirrors in the US FRS. Maybe we can get the wiring, relay and mirrors from the dealer?
Winters suck here in NY and when it rains in the evening, it freezes on the mirrors real good and annoying to get the ice off to see anything.
If the monogram thing is a bust, maybe someone in canada can get the part numbers for the wiring and relays?
morphius88 is offline   Reply With Quote
Old 01-18-2015, 09:08 AM   #10
6spd
6spd's Avatar
Drives: 2013 Raven FR-S
I too interesting in addin' the heated mirror, hope there is a DIY write up!
6spd is offline   Reply With Quote
Old 01-20-2015, 01:12 PM   #11
nadbrz
The only thing I ever got online is this link below,
http://www.phasteksport.com/FR-S-BRZ...rz-mirrors.htm
check the installation Instructions TAB next to description.
I am a novice when it comes to electrical.
Could someone explain this clearly.
Old 01-20-2015, 04:06 PM   #12
frslee
Just drive it
Drives: 13' FR-S
Thanks for finding the instruction.
I'm not an expert either, but here's what I understood. I'm not interested in the side blinker, so I only read the heated mirror.
On passenger side GD2 plug, there's dark blue wire. That's for the rear defroster. Tap that wire with 1 T connector, connected with 2 wires. Each wire goes to each side mirror positive. The negative can be grounded separately.
Don't count me on this!! Correct me if I'm wrong.
frslee is offline   Reply With Quote
Old 01-20-2015, 06:10 PM   #13
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
I'll see if I can get my panel peeled back tonight to take a picture of the wiring on the passenger side for the defroster. I have the mirrors from Phastek with the turn signals and defrosters.
JohnJuan is offline   Reply With Quote
Old 01-20-2015, 08:48 PM   #14
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
The stock heated mirrors are dirt cheap. I mean dirt cheap, we're talking $30. Find them in the parts catalog under Doors >> Outside Mirrors >> Mirror Glass (I'm looking at a BRZ parts page FYI). Once you have the mirror glass you just need to wire them up. Other folks have confirmed that they heated mirror vehicles control the mirrors with the rear defroster, so I'm sure the post suggesting that was on the right track.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
DIY: Auto dimming rear view mirror install Longhorn248 DIY (Do-It-Yourself) Guides 64 01-21-2021 06:17 PM
DIY: APR Door Mirror Install RallySport Direct DIY (Do-It-Yourself) Guides 53 04-26-2019 03:08 PM
DIY JDM frameless mirror install ayau DIY (Do-It-Yourself) Guides 8 01-10-2014 08:36 PM
Part number request for heated seat switch trim azian_advanced Cosmetic Modification (Interior/Exterior/Lighting) 1 09-13-2013 11:02 PM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 06:07 PM
