Old 07-20-2014, 03:09 AM   #1
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Strange rear end 'click'?
So I notice an odd click/clink from the left rear wheel today(exactly like hot metal cooling down after you shut off the car). It seems to only happen when under load, even at the very slightest. I jacked the rear end up, and with the help of my wife, turned the wheels and everything was smooth. However, when taking off, in 1st or even reverse it will generally occur. It's not a guarantee though, sometimes I don't hear anything, and it's not like a consistent patterned noise, like a rock in the tire. It's totally random.
My first thought was diff, but it drives butter smooth, no weird popping, or grinding at all. I have read some threads about a similar noise, and the culprit being loose axle nuts. So I took the wheel off, and re-torqued it. It barely moved, so I doubt that's it. I'm thinking CV joint, but I can't imagine how?
I AM running OFT, with an e85 tune, but surely that's not enough power increase to be popping CV joints? I'm not lowered, and no wheel spacers, or aftermarket wheels. It's basically an all stock car. No drag racing, or auto cross either, but I do drive it like a sports car, with the occasional spirited country sprint, and sometimes sliding the rear end around a bit. I'm at a loss..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 07-20-2014, 03:34 AM   #2
litemup
Drives: around
How long have you been driving it? I remember the first time my wife and I went out joyriding and we both heard this - http://www.ft86club.com/forums/showthread.php?t=13451
We were so concerned at the time, I pulled over and searched all around both rear wheel wells.
litemup is offline   Reply With Quote
The Following User Says Thank You to litemup For This Useful Post:
edeekeos (07-20-2014)
Old 07-20-2014, 03:40 AM   #3
edeekeos
edeekeos's Avatar
Nah, it's not the rear deck. I do have that sound though, albeit very faint so I havent messed with it. This is 100% in the left rear wheel well area. I have around 4500mi on it at this point. Just returned from a 750mi trip if that matters any.
Thanks for the suggestion!
Old 07-20-2014, 04:46 AM   #4
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I have it. No idea what it is though. Only seems to happen when starting from a stop, and what I perceive to be the left side, because that is where I am sitting. My list of potentials are:
U-joint
Axles
Visual inspection looks fine on everything. No negative effects thus far, and I've probably had it for ~4000 miles. I chalked it up to "because race car"
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following User Says Thank You to deucethemoose For This Useful Post:
Old 07-20-2014, 04:52 AM   #5
edeekeos
edeekeos's Avatar
Lol yeah maybe it's been there for a while I've just not noticed it. Hmm. Really curious though, I will say something about my next dealer visit I guess.
Old 07-20-2014, 05:55 AM   #6
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
@edeekeos you have said it's not the rear deck but sometimes these noises aren't that directional.
Here's a fix I came up with that fixed all the noises I was getting from the rear of my car. Only takes 30s so worth a try and even if it doesn't fix the loud noise might fix the feint one you have
http://www.ft86club.com/forums/showthread.php?t=42065
nzer is offline   Reply With Quote
Old 07-20-2014, 11:21 AM   #7
deucethemoose
This definitely is not the rear deck.
Old 07-20-2014, 11:30 AM   #8
Malt
Drives: 2015 WRX
If all you've done to the car is an OFT running an E85 tune, I'd run the E85 out and fill up with gas. Flash to a gasoline map (or stock if you are concerned with them flashing over your tune) and heading to the dealership and letting them diagnose/fix it. You have a warranty for a reason, use it.
Malt is offline   Reply With Quote
Old 07-20-2014, 11:43 AM   #9
BMA
Drives: Twin Turbo
I have this noise as well, it comes from the rear left side of the car. I can even hear it sometimes when just getting in and out of the car with the car turned off. I have no power mods, just some wheels and tires.
BMA is offline   Reply With Quote
Old 07-20-2014, 12:43 PM   #10
mike the snake
My old car used to make clicking sounds from the rear, maybe the wheels or brakes rotors, no one ever really nailed it down, but I would try torquing your wheel lugs, or even swapping rear wheels side to side.
Just removing and reinstalling the wheels got rid of the clicking on my old car.
Old 07-20-2014, 01:23 PM   #11
stugray
Drives: 2013 GBS BRZ Limited
Mine just started doing this last night.
I saw another thread on here where the OP posted a video of him running next to the car and the left rear was clicking away.
In that thread they explained that it is the rear axles and they need to be retorqued.
I think I'll just take it to the dealer and ask them to retorque
Old 07-20-2014, 01:29 PM   #12
edeekeos
edeekeos's Avatar
Yeah, I tried retorquing the axle nut, to no avail. Also, for whats it's worth, I just went and did the rear deck popping fix. Original high piched pop still persists. I will be taking it to the dealer this coming weekend, and see what they think.
Old 07-20-2014, 01:54 PM   #13
litemup
Drives: around
Looking forward to hearing how it works out. Best wishes.
Old 07-20-2014, 02:45 PM   #14
stugray
I think what they mean is behind the wheel where the U-joints (CVs) bolt to the wheel hub.
Strange Noise from rear of car while OFF mike2100 Issues | Warranty | Recalls / TSB 23 12-17-2014 08:14 PM
Rear axle click when entering the car? kurbkilla Issues | Warranty | Recalls / TSB 10 07-01-2014 08:38 PM
Rear driver side clank and click spyingwind Issues | Warranty | Recalls / TSB 11 04-04-2014 11:26 PM
click, clank click sounds when cooling down and more? leaking oil? Boofneenee Issues | Warranty | Recalls / TSB 19 10-02-2013 11:27 AM
Click sound from left rear Tt3Sheppard Issues | Warranty | Recalls / TSB 1 09-25-2013 05:58 PM
