Old 07-22-2012, 06:10 PM   #1
mtsound
Wheel Directory: Motegi Traklite 1.0 16x7.0 +50
I just installed motegi racing traklite wheels 16x7 offset 50mm on my brz
225/50/16 hankook RS3.
The wheels weigh 12 lbs
The tire weigh 25 lbs
Nice track set up, plus some weight savings over stock running much wider tires.
mtsound is offline   Reply With Quote
The Following 4 Users Say Thank You to mtsound For This Useful Post:
MRZ415 (08-31-2012), NWFRS (10-31-2014), why? (01-01-2017), WRB-DZA-BRZ (08-31-2012)
Old 07-23-2012, 08:09 PM   #2
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
These are very nice. I'm not sure whether to get 16s or 17s for the track. I guess 16s are lighter and cheaper.
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 07-23-2012, 08:26 PM   #3
MTeator
First 86
for comparison my 17" tracklites are 2lbs heavier.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 07-23-2012, 08:54 PM   #4
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Winter, I'm totally going w 16's!
Old 07-23-2012, 08:58 PM   #5
mtsound
What size rs3 are you running on the 17 inch wheels
I like the ride of the 16's which will help when I get coil overs
running costs will be slightly less and I got the wheels for 700 on eBay which is the cheapest I could find
Old 07-24-2012, 04:17 PM   #6
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://www.ft86club.com/forums/showthread.php?t=7535
Old 07-24-2012, 05:04 PM   #7
MTeator
First 86
215's.
Old 07-24-2012, 08:23 PM   #8
ft86Fan
ft86Fan's Avatar
So these doesn't come with wheel caps and lug nuts. No issues using the stock lug nuts with these wheels? Your setup should be 7mm closer to the strut that stock. No clearance issues up front? How about center rings? Thanks.
Old 08-31-2012, 12:54 AM   #9
WRB-DZA-BRZ
Cookie Monster
WRB-DZA-BRZ's Avatar
Drives: 2013 Subaru BRZ Premium 6-MT WRB
I love the look of that wheel/tire combo! Makes the brakes look much better too!
WRB-DZA-BRZ is offline   Reply With Quote
Old 08-31-2012, 05:38 PM   #10
mtsound
I am running centering rings, there is no clearance issues in the front, there is at least 1/4 inch i have track three days and no rubbing. you need aftermarket conical lug nuts
Old 08-31-2012, 06:53 PM   #11
gmookher
bery nice
Old 09-05-2012, 10:50 AM   #12
Borden
Drives: 2017 BRZ
Great choice! 16" is the best for tracking!
Borden is offline   Reply With Quote
Old 02-10-2014, 11:24 AM   #13
Yoniyama
Drives: BRZ 2018
Where to find Motegi Traklite 16x7 50mm
I have a hard time finding these. I would be grateful if someone can point me to the right source to find these 12lb 16-inch wheels.
Thanks for your help.
Yoniyama is offline   Reply With Quote
Old 02-10-2014, 12:26 PM   #14
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Depending on your budget, you can also get other 16" wheels around 12lbs if you can't find a set of these.
BRZZZZZZZZZZ is offline   Reply With Quote
Wheel Directory: Traklite Angle 18x9.0 +40 Memphis Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 58 12-24-2014 10:49 PM
Wheel Directory: Motegi MR121 17x7.0 +48 ubersoph Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 05-08-2014 12:20 PM
Wheel Directory: WedsSport SA-90 16x7.0 +33 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-10-2013 01:27 PM
Traklite wheels, not the Motegis JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-14-2012 10:52 AM
