Old 05-05-2013, 09:36 PM   #1
oofie
Track brake pads - front and rear?
Just got my Argento 86 and plan on bringing it to an hpde next month. I plan on replacing the brake pads with better ones. Will do a brake fluid flush as well. The pads will be used only on track and will be swapped out after each event. It will be my first time doing hpde's.
My question is, should I buy pads for both front and rear? Or can I get away with just replacing the fronts and using stock ones for the rears?
Also, any recommendations on what pads to use? I'm thinking something from hawk?
oofie is offline   Reply With Quote
Old 05-05-2013, 11:14 PM   #2
fishek
Drives: H8R FR-S
Will you be on stock tires?
If yes, I recommend Ferodo DS2500. You can run it on both track and street.
If you want to make a small fortune in motorsports, start with a large one
fishek is offline   Reply With Quote
Old 05-05-2013, 11:17 PM   #3
oofie
Yeah, I'll stick with the stock tires for at least a few months. Still have to learn the car and how it behaves.
If I use ferodo for both track and street, is can I get away with just the front pads or just replace them both?
Old 05-06-2013, 12:13 AM   #4
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
if your staying w/ stock tires theres tons of options and youll hear something different from everyone. good luck.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 05-06-2013, 01:02 AM   #5
ImperiousRex
Track Junkie
ImperiousRex's Avatar
Drives: 2013 Subaru BRZ Limited, 2005 S2000
I also use Ferrodo DS2500's for the street and track and I've been very happy with them. I've been consistently placing 3rd in both the FT86 Cup and 86 Challenge events here in CA as well as daily driving the car using those pads. If you're a highly experienced HPDE driver and are looking for the extra couple seconds or tenths of a second to beat the folks ahead of you, then race pads may be in order but if you're still just learning, the DS2500's will be more than enough to start out with.
As for front and rears, I've been using the DS2500's all around. I've been told by faster folks that you want to use matching compounds on all 4 corners and from my own personal experience, the car feels very good with a full set of DS2500's.
ImperiousRex is offline   Reply With Quote
The Following User Says Thank You to ImperiousRex For This Useful Post:
oofie (05-06-2013)
Old 05-06-2013, 01:05 AM   #6
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
go check out WORKS brake pads
they are engineered for both the street use and the track
---> http://www.86-zn6.com/WORKS-Blue-Brake-Pads_p_65.html
86_ZN6 is offline   Reply With Quote
Old 05-06-2013, 01:08 AM   #7
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
Still need to get these on the car but this is the setup ill be daily driving and having fun with!
tuckdaddy is offline   Reply With Quote
Old 05-06-2013, 01:14 AM   #8
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Originally Posted by tuckdaddy View Post
Attachment 36270
when do you plan on setting up? im interested in how that setup will work for DD.
My BRZ
Old 05-06-2013, 01:37 AM   #9
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Shooting for Wednesday! I'm not too sure how the race compounds for the front are going to be (street able or not) but the HPS's are a solid pad! Wanted a good setup for runs and eventually when I can figure out track days and autocross but still be a streetable setup. I'll be sure to fill you in on my impressions of them. I think from the research I've done and just having buddies who continue to buy these for their cars and swear by them they'll be a good setup.
Old 05-06-2013, 10:45 AM   #10
oofie
Thanks! Yeah, I'll stick with stock for the meantime.
Great driving! :happy0180: I've been autocrossing and I'm decent at it, but it would be my first time doing HPDE's, so I would probably be ok with the Ferodo. Thanks for the input!
Looks great! Will look into this.
Attachment 36270
Nice! :happy0180:
Old 05-06-2013, 01:49 PM   #11
CSG Mike
CSG Mike's Avatar
I hope you're not recommending this 950* F pad to people that are trying to track. You'll hit that temp doing a single 60-1 panic stop.
Track pads typically have a maximum operating temp of 1500-2000* F.
As always, you want to prep your car for the most extreme condition it will be subjected to, not what it will normally be subjected to. Martial artists train for years for that 2 minute (or less) bout. Our cars have 200hp, but how much time do you actually spend at redline WOT compared to the time you spend in the car?
orthojoe (05-06-2013)
Old 05-06-2013, 01:51 PM   #12
CSG Mike
CSG Mike's Avatar
@oofie: check out this thread for feedback on different pads.
http://www.ft86club.com/forums/showthread.php?t=23680
Old 05-06-2013, 02:22 PM   #13
oofie
Thanks Mike! So would you recommend having matching front and rear pads? :happy0180:
Old 05-06-2013, 02:32 PM   #14
BRZ NA
Drives: WR blue
I used work blue front and rear pads only with motul 600 last track day in infineon raceway ,it works not bad.through out the whole day,only one or two times felt brake fading,but all at the last round of the session. So I think with slotted front rotors should be good. Or may be additional air duct cooler for summer.
BRZ NA is offline   Reply With Quote
WTB: Carbotech XP8 Front Brake Pads n8dog11914 Brakes, Suspension, Chassis 0 04-17-2013 07:57 PM
rear brake pads donutfilling Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-05-2013 10:43 PM
FS: NIB Hawk HP+ Front Brake Pads djfuller Brakes, Suspension, Chassis 4 02-22-2013 11:59 AM
Delete driver01 Canada Classifieds 1 01-11-2013 05:51 PM
Hawk HP Plus front brake pads on the track mtsound Tracking / Autocross / HPDE / Drifting 30 11-15-2012 02:24 PM
