Old 08-06-2018, 05:04 AM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
Bottom half of engine caked in grime. Doesn't seem like a leak
I've had a driver's side timing cover leak in the past and it's been resealed three times. But this time it looks like something else. It seems like the grime is all under the engine and in a way like it was misted on. Can't tell from which direction but looking at certain bolts, it's not entirely covered. Could it be an exhaust leak? I'll get more pictures when I change my oil jn a few weeks but it just looks strange.
tracerit is offline   Reply With Quote
Old 08-06-2018, 05:43 AM   #2
Verl0r4n
Drives: GT86
Looks like belt dust to me
Sent from my SM-G950F using Tapatalk
Verl0r4n is offline   Reply With Quote
The Following User Says Thank You to Verl0r4n For This Useful Post:
tracerit (08-06-2018)
Old 08-06-2018, 09:45 AM   #3
Fred E
Drives: WRB BRZ
Maybe belt dust, but that might actually be all over the front face of the engine instead of only at the bottom/under. If you remove your header, my guess is you will see evidence of an exhaust leak at the flange and it would likely just need new gaskets. Should be about $100-150 for parts and labor if you go to a shop, or only like $30(?) for new gaskets if you do it yourself.
Fred E is offline   Reply With Quote
The Following User Says Thank You to Fred E For This Useful Post:
Old 08-06-2018, 09:59 AM   #4
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
You can clearly tell he has a leak somewhere and the dirt is accumulating onto the leaking oil spots. You can see the oil all over the grounding strap. Look into your oil filter cup and see if there is oil in it, if it fills up you can end up with oil all over the bottom of your engine, mainly on the drivers side but if it hits the belt it'll go places.
https://www.ft86club.com/forums/show....php?p=3092526
Trueweltall is offline   Reply With Quote
The Following 2 Users Say Thank You to Trueweltall For This Useful Post:
tracerit (08-06-2018), ZionsWrath (08-06-2018)
Old 08-06-2018, 10:08 AM   #5
ermax
ermax's Avatar
The timing cover is notorious for leaking at the bottom right near that wet ground strap you focused on. The oil will blow around and collect dirt everywhere. That leak will just get worse. Mine was much worse but it didn't spread around as much as yours has. Definitely not and exhaust leak though. If you had a leak that bad you and all your neighbors would hear it.
There is a thread around here somewhere where someone sealed his leak externally. He cleaned up the area really well and then used some sort of RTV and his hasn't leaked for a year.
The Following 2 Users Say Thank You to ermax For This Useful Post:
tracerit (08-06-2018), Ultramaroon (08-06-2018)
Old 08-06-2018, 10:57 AM   #6
tracerit
I'll replace the serpentine belt and see where it goes from there. J. At 64k miles now.
As for the grounding cable, I looked back and old footage after they resealed a year ago and it looks the same. They just didn't clean it. I should probably clean everything up, replace the belt, and then reassess from there.
The Following User Says Thank You to tracerit For This Useful Post:
ermax (08-06-2018)
Old 08-06-2018, 10:59 AM   #7
ermax
ermax's Avatar
Surprised they would crack open your timing cover without cleaning first. I wouldn't take my car to that dealer ever again that's for sure.
Old 08-06-2018, 11:02 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
This makes the most sense.
The amount of grime, particularly "wet" looking. This is just my bro-science analysis though. I don't know how to say it but you can just tell when there is some other issue that accumulates debris from run of the mill old age and dust.
Black gunk on bottom of engine? UPDATED (Oil leaks) tomato86 Issues | Warranty | Recalls / TSB 36 10-25-2016 03:13 PM
Engine starts but doesn't run driftking96 Engine, Exhaust, Transmission 31 02-19-2016 10:49 PM
Buzzing sound from engine when ignition half on ChrisD Scion FR-S / Toyota 86 GT86 General Forum 18 10-09-2015 01:20 PM
Which Meguiar Product Removes dirt and grime? Mikeez Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 26 03-01-2015 08:39 AM
Engine doesn't start right away Cajun Issues | Warranty | Recalls / TSB 1 02-04-2013 02:09 PM
