Old 11-25-2016, 11:16 PM   #1
MatthewFRS
Unhappy CEL + Losing Traction Light on after E85??? (Picture included)
Hey everyone, I really hope that you guys can help me here. So I just got my car tuned at my local tuner for E85. Runs great, the extra power and low price of gas is amazing!
Fast forward a day or two and both the CEL and my losing traction control light come on and are solid. Does anyone know how to defeat this? Because of it, I can't use my cruise control, when I try to turn it on, it's a solid orange color instead of green.. Does anyone have any tips?
I've had my tuner reset the ECU and the light came back. I also disconnected the battery for about 15 minutes and the light went away, but came back like 5 minutes later after the car stopped stalling and finally learned the E85 again.
https://i.imgur.com/iKAJTaV.jpg
Thank you to anyone in advance! I will be checking this post in the morning, and if I get any quick replies I'll respond soon!
2013 Automatic FRS if you are wondering
MatthewFRS is offline   Reply With Quote
Old 11-25-2016, 11:21 PM   #2
ryoma
ryoma's Avatar
get an OBD2 scanner and find out what the code is. what else did you install recently aside from a tune?
Old 11-25-2016, 11:22 PM   #3
MatthewFRS
Nothing else installed on the car. Only other stuff I have done to it is TRD Intake, and TRD Exhaust.
Old 11-26-2016, 11:01 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
It shouldn't need learning and shouldn't be stalling until it does. My guess would be fuel trims maxed out based on that statement alone.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-26-2016, 11:35 AM   #5
MatthewFRS
The computer does learn, it's strange to see it lol. It has to "learn" the new gas. My Tuner had to do it, and I have to do it when I reset the ECU. It turns on, it stalls, it learns, it turns on, it idles.
Old 11-26-2016, 12:54 PM   #6
You need to get the code scanned and correct the issue. If it is going into "limp mode" (trac light on and no cruise) it could be a wheel sensor to a cam issue and just about any conceivable thing in between. You can't just defeat the CEL and carry on. Could be a minor problem with a 5 minute fix or you could throw a rod (or again anything in between). Get it scanned and come back with the code and we can help.
The ECU takes about 100 miles of driving to learn the fuel and like was said it should not be stalling while doing so.
Old 11-26-2016, 12:56 PM   #7
MatthewFRS
I will update when I get the code scanner tomorrow! Coming in the mail
The Following User Says Thank You to MatthewFRS For This Useful Post:
Tcoat (11-26-2016)
Old 11-26-2016, 12:57 PM   #8
Drive as little and as calmly as possible until you pull that code. There is a risk (small but still a risk) of damaging something.
MatthewFRS (11-26-2016)
Old 11-26-2016, 06:48 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'm fully aware how the ECU works, there's not that much "learning" that goes on. Your tuner should have done a better job. If the fuel trims are so rubbish it stalls, then just bloody correct it.
.: Stealth 86 :.
Kodename 47 DJ:
Sportsguy83 (11-29-2016)
Old 11-26-2016, 06:55 PM   #10
MatthewFRS
Oh, well I'll let him know next time he tunes it. He told me it was the first time tuning for E85 on an FRS.
Old 11-27-2016, 12:15 PM   #11
MatthewFRS
Here's the code. Any advice?
Old 11-27-2016, 12:49 PM   #12
MatthewFRS
I've just posted an update, any ideas?
Old 11-27-2016, 01:35 PM   #13
TelMinz
Rotary for the win
Drives: BRZ, FD3S RX7
System too lean means you're not getting enough fuel, or an exhaust leak which is allowing too much air in. Or maybe even something else entirely like a faulty O2 sensor
"Behold, my field of phucks, lay thein eyes upon it, and notice, tis' barren."
TelMinz is offline   Reply With Quote
Old 11-27-2016, 01:37 PM   #14
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I would check for intake leaks, exhaust leaks, MAF sensor, o2 sensor
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Shuddering from rear when losing traction nickmerronesucks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 04-30-2022 05:32 PM
Car losing traction in corners Chase1996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 82 03-06-2016 07:50 PM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
losing traction? sskillzz12 Engine, Exhaust, Transmission 4 03-24-2015 09:51 PM
Lowered Car, Losing traction while getting off drive ways 86_ZN6 Scion FR-S / Toyota 86 GT86 General Forum 54 10-26-2012 10:02 AM
