| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 15' Frs
First time changing oil
Hey guys it's my first time changing oil in the frs. I looked at the gasket the one that came off from the factory(painted black) and it looks thinner than the one I bought. I'm I suppose to use the crash washer that came with the filter?or leave the painted black(thinner) from the factory?
Thanks ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk Last edited by Jonathanlim; 01-22-2016 at 10:45 PM. |
#2 |
Drives: 2015 CWP BRZ Limited
Use the new crush washer.
#3 |
Drives: 15' Frs
#4 |
| The Following User Says Thank You to jawn For This Useful Post: | Jonathanlim (01-22-2016) |
#5 |
Drives: BRZ Limited
Its a crush washer. Your old one is crushed. The new one is just not crushed yet until you tighten it. Everything you have looks as it should.
The old one is only black because they painted the oil pan with the drain plug and washer installed. My washer was glued to the nut with paint when I did my first change. |
#6 |
Same with the oil filter ..... take off the old rubber gasket, use the new one ..... NEVER two together.
DO NOT over tighten the oil pan drain plug, snug it down to the crush washer, snug a bit more to crush the washer then about 1/4 to 1/2 turn more. Or use a torque wrench. Remember to only "hand tighten" the oil filter ..... unless your hands are greasy and/or you have a weak grip..........then you may give it a final nudge with a filter wrench. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Jonathanlim (01-23-2016) |
#7 |
wait... the oil filter has a removable gasket?
#8 |
Drives: 15' Frs
#9 |
the gasket on the filter itself? I didn't know that comes off unless you specifically try and remove it lol
#10 | |
HOWEVER, if someone had put the filter on and didn't put a thin film of oil on the rubber gasket and over tightened the filter and broke the seal, the old gasket could stick to the oil filter housing. So, if you don't notice it and slap the new filter on with a new gasket, you now have a double gasket ....... which when tightened, may scooch out and the oil filter will leak. Not so much of a problem with our oil filters because they are on top and can be seen. Not like ........the old days ...... when we had to lay on our backs, under the car, on a cold, wet, gravel driveway, in the dark, on a snowy winter night and change the oil filter........ humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Toyarzee (01-23-2016) |
#11 | |
#12 | |
#13 | |
Drives: FR-S,GTI
| The Following User Says Thank You to WNDSRFR For This Useful Post: | humfrz (01-23-2016) |
#14 | |
| Changing Factory ECU | Skorov | Software Tuning | 7 | 09-25-2015 10:35 PM |
| Tax return time = WHEEL CLEARANCE TIME from Gram Lights and Yokohama | vividracing | Wheels and Tires | 4 | 04-04-2014 02:46 PM |
| changing emblems | beaver_scott | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 02-23-2014 06:02 PM |
| BBS Lm changing barrels? | manonastick | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 12-17-2013 05:43 AM |
