| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
hey you, yeah you <3
Drives: 2014 37J FR-S
Steel wool 00000 to clean wheels?
Yes or no?
Wheels as in rims. (oem)
#2 |
No.
Even if cleaning unfinished aluminum, never use steel wool. Microscopic iron particles are embedded into the surface of the aluminum and induce pitting through galvanic corrosion.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | johan (01-17-2016) |
#3 |
Drives: 2015 CWP BRZ Limited
Nope! How dirty are your wheels?!
#4 |
Not too dirty...yet...
Just an old geezer at Orilleys overheard me talking about having trouble giving my wheels a shine since they've begun to have a thin layer of dirt and brake dust setting in on the interior portion of wheel. Anyway, he owns a older Camaro (70's) and he recommended using the wool. His little secret he said and bought like 3 packs. I bought one. Not sure how to clean rim. Seems every time I clean it, shine goes away? I clean wheel with hot water but not boiling, brush with a soft brush and then wash once more after heavy dirt is off. Sorry if it don't make sense. I have a killer headache.
#5 | |
| The Following User Says Thank You to jawn For This Useful Post: | Packofcrows (01-17-2016) |
#6 |
you can also try a wheel cleaner. the one I use turns brake dust into a red color once I spray it on. the one I use is called Sonax wheel cleaner and you can buy it for about $20. you just spray it on and let it sit for about 5-10 minutes, then spray it off with water.
| The Following User Says Thank You to ryoma For This Useful Post: | Packofcrows (01-17-2016) |
#7 |
Bahhhh...
Been cleaning car for 4ish hours with doors open and radio on. Tried to turn car on to swap in garage.... just clicks, wont turn on. No CEL, all lights work, radio too...but just wont turn on. Fk the wheels for tonight. Im going to bed. I'll look up Sonax tomorrow and waxing wheels after i diagnose if its battery, fuse or starter/alternator. Thanks guys. Guess ill save the wool to cover garage mice holes.
#8 |
most likely it's your battery. 4 hours with the radio on is pretty long lol. a jump start should fix your problem
#9 |
Drives: 2014 GT86
"just clicks" - current not sufficient to turn with starter crankshaft, but slight remains of juice still left in battery. Hmm, radio on .. doors open=probably on interrior light .. hadn't experimented this way, but 4h sounds believable. Just ask some neighboor with jumstart wires to park besides, start up, let it idle for at least half an hour, or drive a bit, to recharge.
#10 |
Get down in there with a toothbrush if necessary with only car soap and water. It will take time. What I did after is use this 3M synthetic wax and sometimes the brake dust just rinses right off. If not use dedicated microfiber cloths. Spray solutions just cant get into spots your finger can.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#11 |
Used battery kick starter. Car purred to a start!
Ended up washing with dish liquid soap, scrubbing with brush, then waxing twice. Looks brand new! Pics tomorrow if I dont forget. Thanks guys!~
| FS: Studded Kumho I-Zen KW22 on Steel Wheels | atomedge | Canada Classifieds | 1 | 10-23-2015 08:17 PM |
| Lug nuts for steel wheels | nmastereal | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 11-03-2014 09:03 PM |
| Searching for a quality wool wash mitt | Cjymiller | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 04-18-2013 10:19 PM |
| Painting steel wheels? | jm1681 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 10-04-2012 03:36 PM |
