Drives: asphalt fr-s
Transmission kick under accel
Anyone experiencing transmission knocking under wheel spin off a start?? I get the usual shifter shake, but also some ''dry'' knocking of the tranny underneath..
anyone else?? fixes?? tranny support/mount maybe? Thanks ![]()
#2 |
i'm sorry, what?
Drives: Canada
auto or manual?
#3 |
Sorry, should've specified... it's manual
#4 | |
Drives: 2015 Scion FR-S
Based on my hunch, I've bought diff outrigger bushings, diff mount bushings, and subframe bushing inserts. I'm hoping that's enough to keep everything where it should be. |
#5 | |
#6 |
#7 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Yup, it's wheel hop. It's pretty intermittent in our cars and it really isn't too bad compared to some other cars I've launched in. Like@Travisty75 said, there's a few things you can get to alleviate it, but it's really just something you gotta live with when you have IRS.
- The Ancient BRZ Sacrament by Zaku |
#8 |
Drives: '14 WRB BRZ 6MT Limited
This is likely wheep hop if it felt like a juddering from the rear end with vertical vibrations. Its a common issue with RWD cars with many different types of suspension set ups. I get it in my Mustang with a stick axle - its worse in the wet. Older CTS-V's could axle hop so badly they would blow up differentials. Fixes range from driving adjustments to adjusting suspension geometry.
#9 |
Thanks for input everyone. I'm kind of relieved... will still keep an eye open and update thread if it ends up being something that may be of interest to the community.
#10 |
Drives: Attitude
There are mounting points you can stiffen to prevent slop (engine mounts, trans mount, rear diff mount, rear subframe inserts, 1pc driveshaft) and minimize wheel hop, but as others have said it's the nature of the beast.
#11 | |
Drives: FR-S 6MT
IRS set ups aren't good for abrupt hard burnouts. At least in my experiences.. |
#12 | |
Drives: Attitude
Short search link (LMGTFY, forgive me): http://bit.ly/1ooDBaL |
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Mikem53 (03-18-2014) |
| Automatic Transmission Kick/Choke when shifting gears | Tech Gremlin | Engine, Exhaust, Transmission | 13 | 06-16-2015 01:54 AM |
| PTUNING Summer Kick Off meet & dyno | Freddy@PTUNING | Mid-Atlantic | 13 | 05-20-2013 03:41 PM |
| for socal (405/605fwy) people. does the HD Radio kick in and out often? | tracerit | Southern California | 16 | 04-10-2013 08:55 PM |
| Knock/valve slap/crick noise under accel | yomny | Issues | Warranty | Recalls / TSB | 47 | 01-07-2013 08:53 PM |
| Apexi SMART Accel Controller | 808Raven | Engine, Exhaust, Transmission | 2 | 10-11-2012 07:54 PM |
