Old 09-05-2018, 06:23 PM   #1
Hanson
Hanson's Avatar
Drives: 2018 86 gt black Halo
MRR wheels
I looked through all these post and couldn't find anything on these wheeks, well I order MRR Ground force Gf 07 wheels, formed flow cast wheels they cut offset in wheels, 2 3 week delivery time I order 8x18 front 9x18 rear , I have coilovers, they are doing the math, but I seen nothing here, In put, please on This brand,
Hanson is offline   Reply With Quote
Old 09-09-2018, 03:45 PM   #2
Hanson
Hanson's Avatar
Here's what I order MMR GF 07
Old 09-09-2018, 03:50 PM   #3
Hanson
Hanson's Avatar
They put offset in, no guess work,
Old 09-09-2018, 04:08 PM   #4
swarb
No stagger. Search why not.
Old 09-09-2018, 05:07 PM   #5
Hanson
Hanson's Avatar
Yes i,m getting stagger fir, going to take 2. To 3 weeks for delivery, on posting here, i,m a super noob, trying to figure things out, resizing pictures , my tire size will be 225x40x18 255x35x18 tein z ciolovers get install this Wednesday, any input on posting appreciated,
Old 09-09-2018, 05:44 PM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Staggered will induce more understeer. Most people want to preserve the balance and get a square setup (same width front to back).
In my opinion 255 is waaaaaay too much tire for the rear of this car, unless you only do it for looks and don't care about handling.
Old 09-09-2018, 06:10 PM   #7
Hanson
Hanson's Avatar
I use to race dirt track in my younger year, bombers, sportsmen, latemodels, and dirt trucks, been there done that thing, this is my work ride, no racing 100% my eye candy work car, I want that 60 ,, 70. Look big tires on back smaller on front, starting going to big up front , very hard on steering components, i,m a fat old papa, now, stopped driving the big 4x4s now low and mean lookin, , thanks ,
Old 09-09-2018, 06:11 PM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I looked at these on ebay. 18x8 +35 & 18x9 +40. I have staggered wheels in similar spec. I went with 225/40 & 245/35. Now have 215/40 & 245/35.
Id stick with a smaller stagger, like 225/ 245
I just ordered 2 more wheels so that ill have 9" on all four corners. Staggered is NOT ideal. It looks cool though.
Also, offset calculation does not involve "guess work". I really like https://www.willtheyfit.com
It is a good "calculator." And by reading the wheel gallery. I know what the limits are between the fender and spring perch. Punch in the OEM wheel and tire specs, add the new wheel specs and compare.
I LIKE TIRES!
Old 09-09-2018, 09:05 PM   #9
Hanson
Hanson's Avatar
Ok my bad on wording, on guess work, on almost all the wheels I looked at they mostly only offer 35 ,40, 42,45 offsets, and it seemed when I done my math, in the wheel width I wanted, I couldn't find the correct offset, with MRR they use blanks, plug in your car, suspension, wheels, then ccm the offset for your desired look, correct, this isn't guess work, thanks for the input.
Old 09-09-2018, 11:06 PM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Cool! What kind of look are you going for? I had 18x8 +45 and 18x9 +42. First I added a 10mm front and a 5mm rear. Then I moved the 10mm to the rear and put 25mm on the front. I now have 12mm rear and 25mm front.
This makes the offsets 18x8 +20 & 18x9 +30. My only suspension mods are 1" Eibach prokit springs and Spc EZCam camber bolts. I have -1.4 front and -2 rear.
I LIKE TIRES!
Old 09-10-2018, 05:25 PM   #11
swarb
Do you want wider tires or do you want taller tires for theat rake look?
245/40 in the rear for the rake.
255/35 for a little bit of both.
The Following User Says Thank You to swarb For This Useful Post:
Leonardo (09-10-2018)
Old 09-10-2018, 09:56 PM   #12
Hanson
Hanson's Avatar
Element wheels is the supplier for MRR, I didn't want or really wont use spacers, my own personal reason, but these guys, in theory will give me the flush look stagger fit. In a couple weeks i,ll post them, I really wanted feed back on MRR, I read a lot of post in tire and wheel, and some made comments about cheap wheels, are MRR wheels, cheap, wheels,
And I just had to post one of there banners, there web site has some frx, brz, there, in photos,
Old 09-13-2018, 07:32 PM   #13
Hanson
Hanson's Avatar
Pictures
225 45 18 on 8x18 MRR GF07 wheel front
255 35 18 on 9x18 rear
Tien flex z ciol overs,
Still can drop a lot on coilovers, no rub
The Following User Says Thank You to Hanson For This Useful Post:
fika84 (09-14-2018)
*Wheels Collection* Winter Package 2015-2016 (Alloy Wheels + Tires) wheelsco Canada Classifieds 4 10-08-2015 03:55 PM
Discount Tire installed my wheels and tires...and damaged my wheels...advice needed! stratodyne Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-17-2013 02:21 PM
Wheels, Wheels, Wheels | Island Import Performance IslandImportPerformance Wheels and Tires 4 07-31-2012 10:08 PM
