Old 04-03-2018, 06:53 AM   #1
evoto86
Drives: manual Toyota 86
curious did your tune make the FA20 run smoother ?
The FA20 is not the smoothest engine to rev out by any means, wandering if a tune helps or headers ?
evoto86 is offline   Reply With Quote
Old 04-03-2018, 07:41 AM   #2
Grady
Grady's Avatar
Tune a little, E85 a lot!
Old 04-03-2018, 09:23 AM   #3
BRianZ 14
Drives: 2014 BRZ Premium
Its all about E85
For real man, that tune totally changes the car...no headers or exhaust required. Kills your gas mileage, but if you aren't driving this car with a lead foot you're not doing it right.
BRianZ 14 is offline   Reply With Quote
Old 04-03-2018, 11:34 PM   #4
Windycitystig
Drives:
Tune Only or tune and e85?
Windycitystig is offline   Reply With Quote
Old 04-04-2018, 07:48 AM   #5
evoto86
I am that’s the problem I notice it’s biggest flaw and that’s how it delivers 200 ponies like a drunken sailor or somebody let a drunken sailor come up with the tune.
Old 04-04-2018, 09:28 AM   #6
BRianZ 14
The OFT is a tune for e85 so its both.
Old 04-04-2018, 12:39 PM   #7
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I get better average MPG with a tune. I/H/E.
Trueweltall is offline   Reply With Quote
Old 04-04-2018, 01:34 PM   #8
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
So i did a tune + headers + flexfuel all at once.
Headers help kill the torque dip - but there is no doubt the tune helped take full advantage of this. The flexfuel (and subsequently running on e85) was really cool... I’d highly recommend it because for a simple mod, and a small decrease in fuel economy you get a nice bit of extra shove/torque/power.
Personally highly recommended to do all 3 if you can - made my car so much nicer day-to-day and so much more fun when you want to drive a bit quicker
I like driving!
86 South Africa is offline   Reply With Quote
Old 04-04-2018, 02:13 PM   #9
Lantanafrs2
Drives: 2013 frs red
The smoothest combo is header/tune/e85. With stock manifold even e85 felt a little abrupt down low.
Old 04-04-2018, 02:32 PM   #10
Jasonb
Drives: 17 Series Yellow BRZ
On my 2017 manual, the v4 stage 2+ OFT tune made a huge difference.
Jasonb is offline   Reply With Quote
Old 04-04-2018, 03:44 PM   #11
strat61caster
strat61caster's Avatar
eh, don't get too hyped yet
imho a tune specifically helps smooth out low revs low load conditions, the idle should be a bit smoother as well as everything below 3.5k
revving the fa20 out to 7.5k rpm will still sound and feel like it does before the tune/header, at least if you stay EL
And you'll likely pick up that weird vvt noise around 4k
http://www.ft86club.com/forums/showthread.php?t=59475
ineedyourdiddly
Old 04-05-2018, 10:36 AM   #12
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Besides e85 giving more HP and nuking your MPG, I love e85. The car sounds different and running way smoother with it. My local station has e85 @ 74% year around and that's all I run. I might put 93 in her every bluemoon to just do it but it's a huge difference. It could have everything to do with the ignition timing being advance to the max when running E85.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
[review]Stay away from Ecutek FA20 tune(stg2) if..... WatchmaN Engine, Exhaust, Transmission 46 06-06-2014 04:57 PM
Why the ecu make my tune run richer over time ? NoFear99 Software Tuning 64 04-22-2014 07:57 AM
stupid yet curious question(fa20 turbo) friss21 Forced Induction 2 03-24-2014 07:55 AM
I have joined the FI fray--P&L kit/FA20 tune GTB/ZR-1 Forced Induction 41 10-03-2013 07:35 AM
fa20 club e85 tune with L/C,uel headers and perrin everything else :) brz2013 Engine, Exhaust, Transmission 20 07-17-2013 12:39 AM
