Originally Posted by xjohnx
How difficult was the soldering?
Umm I have tipped the faceplate and headunit but not done the wiring bit yet. It pretty easy but I'd recommend you tip both wire and headunit before soldering to avoid heat transfer. Plus you should apparently use untwisted pair cat5e. Not sure why though.
