Originally Posted by Sportsguy83
You will connect your O2 Wideband in the slot where the secondary O2 is palced from factory.
You will connect your Wideband gauge connection as normal, from the O2 harness into the Wideband gauge inside the car.
Now, you need a Wideband gauge that has a 0-5V output cable (example FAilsafe gauge). You will use the Wideband output 0-5V cable and connect it to Moto Mike's harness, and will plug said harness into the car's stock rear O2 electrical connection.
I wish I had that option available when I did mine, it looks very clean.
Not sure if you know but does the harness from Moto-mike have just one wire coming out of its connector for the 0-5v ouput or it has that power/ground others are mentioning?
Thanks a bunch..if made any simpler you'd have done it for me lol. Thanks man.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
