Expected Negative Camber / Toe for 1 in Drop
About to install a set of TRD / Eibach Pro springs on a '18 PP. Is there a ball park negative camber for front / rear I might expect from those that have done similar? The drop should be close to 1 inch from what I understand. I don't mind running 1-2 degrees negative since I autocross this car about once a month. I think I'll be okay from what I've seen for just an inch, but I had trouble pin pointing the answer. Also should I expect any toe in? Either way, I'll have the alignment checked and adjusted. I just want to have some camber bolts or LC arms in hand for that if they'll be needed. Thanks for the assist.
2 Attachment(s)
My '17 is lowered on Eibach Pro. Toe will of course be off. Front camber doesn't really change, MacPherson struts in the front.
Rear camber will be way out, mine was -3/-2.5 degrees. Visibly bad. Moog LCAs and it's all dialed in, I did not need to install the offset rear toe bushings. SPC front camber bolts as well. See my thread here, exact same situation. https://www.ft86club.com/forums/showthread.php?t=132421 Before and after. Specs are in degrees and minutes, not decimals. |
-2.5* of camber sounds like a dream alignment to me :iono:
I thought the springs on the PP would be better than the pro kit springs...interested to know how you like it in comparison. |
-1*40' was as much camber as I could get on the front with just the SPC camber bolts. |
I'll bet it rides rougher and doesn't handle any better :D |
I've had good luck with the Eibachs and there progressive springs on other cars. A descent compromise for a daily driver with occasional track. Could have gone hard core for handling, but like I said, trying to comprise. Closing the wheel gap just little won't be so bad either. It's nothing that can't be undone if doesn't work out. |
The SPC with toe kit is slightly more expensive the the MOOG without, not much. But if it's not needed then I won't bother and just order the MOOG off Amazon. |
One of the brands (Whiteline?) presses out the inner joints and supplies bushings for SCCA requirements. I did not need the rear toe bushings for that drop and camber. The less negative (closer to 0) the camber the more travel you need on the toe link I believe it was. If you want -1 instead of -1.6 you would need to install the bushings at 1" drop. Straight from the Moog box, offset bushings included. |
It would probably be better off with the extra bump travel. Springs will bump you a class likely, and if it's SCCA based you'll now be in STX unless TRD springs are allowed in stock on BRZ's (and they're actually TRD springs, not eibach branded), I haven't been keeping up much.. |
| All times are GMT -4. The time now is 05:40 PM. |
User Alert System provided by
