-   -   OFT or Crawford Billet Performance Blocks (https://www.ft86club.com/forums/showthread.php?t=124715)
Bkdshadow 01-16-2018 04:21 PM
Hey guys,
So I was originally going to save up for the OFT, but then read some of the forums on here about the Crawford BPB and how it basically helps compress the powerband and makes it more enjoyable as a DD. I am going to get an OFT eventually when I get my tax refund along with a nice set of headers, but I’m thinking that getting the BPB would be a worthy investment right now.
What do you all think? Should I just save up and get the OFT with the UEL and not even get the BPB, or get the BPB now and eventually do the OFT stage 2 uel +BPB. I don’t plan on going FI for what it’s worth, just want a good NA build.
Sorry if this is something I could’ve found searching more, I’m just trying to make sure my thought process is sound with this
Thanks!
bfrank1972 01-16-2018 04:39 PM
OFT first - BPB's later. You'll really want to optimize for the BPB's to get the most and OFT will allow you to do that (along with benefits across the power band).
NoHaveMSG 01-16-2018 05:08 PM
I don't think I would bother with the power blocks. A catless header and a tune will flatten out the torque dip.
Bkdshadow 01-16-2018 06:00 PM
Cool, thanks for the feedback!
Bkdshadow 01-16-2018 06:01 PM
I see what you’re saying. I think the appeal for the blocks would be the fact that the power comes on earlier right? This is the thread that made me want both.
http://www.ft86club.com/forums/showthread.php?t=62007
Xxyion 01-16-2018 06:02 PM
From what ive noticed from driving someone with the BPB, is that is effectivly moves most of the power down to DD range. So you'll feel more oomph between 3-4k RPM. OFT with headers does roughly the same. However i would recommend getting the OFT and headers first. AFAIK you need to tune for the Power Blocks and you will need something to tune your car with. So get the OFT first cuz you'll actually be able to utilize it.
Hiko 01-16-2018 06:53 PM
I've installed an OFT, header (catted EL) and the Crawford BPB, in that order.
I'd stick with what others are saying here, OFT first. It gives you the whole package of mid-range gains, top end gains, better pedal feel and room to grow in the future.
But if you're more DD oriented, do swing back to get the BPB's. The mid-range gains are completely worth it, even with the rest. And IMO, they also makes the car easier to drive. The main downside of them is that, at least untuned, there really is quite the 'wall' at 7000rpm.
Bkdshadow 01-16-2018 07:13 PM
Yeah it seems like that’s what a lot of people are telling me. From what I’ve seen the tune isn’t required for it, and it actually drops off higher end power (if not done with the specific BPB tune).
I think the reason I’m so conflicted is that my car is bone stock, and the OFT by itself wont be as dramatic as the BPB (or obviously the OFT+headers). Hearing that I could reach peak power at like 6500 RPM as well as reducing the torque valley. Not trying to be difficult, just weighing the pros and cons I guess.
Bkdshadow 01-16-2018 07:20 PM
Just saw this, but ok got ya. Yeah I’ve always been under the impression that the OFT by itself doesn’t give as much torque as I’d like, but if you’re saying that’s not quite the case then I’ll wait then :thumbsup:
Thanks a lot for the wisdom guys :D
bfrank1972 01-16-2018 07:44 PM
It's not really a wall, and with some tune tweaks Shiv was able to get it back. FYI you may encounter some naysayers with the BPB's, saying they're snake oil :) Not at all the case:
Shiv with OFT
http://www.ft86club.com/forums/showthread.php?t=62471
Moto East (a VERY reputable tuner) with ecutek ,P&L headers & E85
http://www.ft86club.com/forums/showthread.php?t=67520
DIY tuning with OFT to get most of the top end back
http://www.ft86club.com/forums/showthread.php?t=71285
Take a look at the midrange surge. It's not about the torque dip really, although it can make the dip 'narrower'. It's really about the surge in power past 5000, at the expense of a couple hp past 7000 (where most of us spend very little time honestly). Good headers will help the torque dip, the ideal would be to do both and then have Shiv do a custom e-tune for you. Will make the car much more entertaining to drive.
NRXRaptor 01-17-2018 06:07 AM
Imo the stage 1 OFT tune hardly changed anything for me. If I were you I'd get some headers to go along with the OFT. Headers and the OFT tune did way more for me than the OFT alone with just a catback
NoHaveMSG 01-17-2018 01:17 PM
Yeah it shifts everything down. Not saying the CPB don't do anything. But for 300 bucks I think across the board it's a better investment to just save a little longer and go with a header. Just my opinion. I will likely try a set later on in the year to see if I would like it. My car already pulls pretty good from 4k up.
bfrank1972 01-17-2018 01:44 PM
Yup I agree, OFT + a good set of headers is the best starting mod for this car. If you're strapped for cash, pick up an OFT first - it definitely made a noticeable change with my car, more responsive motor, a bit more power, smoother and easier to drive. Then save your pennies and watch the classifieds here for a good quality used header. Then save a few more pennies and look for a used set of BPB's on here, you see them from $150-$200 on here when they pop up. I'm in a total of $900 for my OFT, P&L header, and BPBs (yeah I'm cheap :D ). After that I think NA bang-for-buck goes to final drive upgrade.
S. Snake 01-17-2018 02:29 PM
OFT owner chiming in. If I had it to do again I would definitely buy the OFT first as the stage 1 tune changed the way the car drives. Throttle response is on point and the torque dip while still there I would say has 80% been eliminated and you can use the OFT as a Gauge pack that can read your temps, afrs, and such and it can be used to read and clear gel codes. The only mods I have are a cat back and OFT.
Plus if you are gonna go FI in the future the bpb from what I read should probably be removed. Lastly you can always sell the OFT for good money if you move up to Ecutek.
