Do you still have the Prova mirrors? Curious how they're holding up all these years later, trying to find a set is next to impossible since they're discontinued.
Thanks for the reply! I have managed to track down a new interior rear view mirror, but the exterior ones are definitely a challenge. If the lettering fades I may end up just getting the OLM/ off-brand ones. Functionally, I know they're all the same but I like the Prova brand and niche Japanese parts. |
Car's at just over 89k miles. Picked up my car today after it being at the mechanic for 3 months. Started having a lean engine code. I found and fixed exhaust leaks where the gaskets were, replaced the MAF, cleaned the throttle body, replaced the ignition coils, but nothing fixed it so I took it to the shop.
-The largest issue, and the last issue identified after all of the below was fixed was the throttle seals in the supercharger elbow and valve, which are supposedly known to have a faulty design in the early models that wear out and leak. The elbow was shipped back to Sprintex and they replaced the parts and bearings in the valve area. Sprintex shipped my parts to the wrong state so there was a week delay. -The gasket/seal around the supercharger to the intake manifold had leaks. They replaced it. This took over a week to get the part. -There were a lot of vacuum leaks in hoses that were brittle and aging after 10 years and multiple track days which needed replacing. -The MAF sensor I bought to try to fix the engine code from Autozone wasn't reading correctly so they put in a Denso branded one. -There were a couple small leaks in the JDL exhaust headers that were welded back up. -They replaced the 2 sensors before and after where the cat used to be that plug into the headers. -I had them clean, service and replace all 8 fuel injectors/seals. This was another multiple week even in which they were sent the wrong tool to remove the injectors then the wrong seals as the injectors on the older BRZs were different than later ones so the place they got those tools/seals messed up. This was a few weeks of headache for everyone as well. Sprintex originally said leaks in the valve/elbow is normal even when the shop sent them a video of all the smoke coming out of it at idle. Doesn't leak anymore with their new parts. My shop called the tuner at one point and asked them about checking the tune. They said it's not their problem and not the tune. Makes sense since the engine/tune has been the same for 8 years, but they could have been nicer and more helpful. Special thanks to the guys at Jon Bond that service superchargers like the Sprintex as they were very helpful to my shop in discovering the Sprintex elbow/valve/bearings issue and getting Sprintex to put the new parts into the elbow. The car ran well on my drive home and it's weird how the car is much quieter with all the leaks from the exhaust and vacuum. Pulls harder than my recent memory remembered. Finally this bad dream is over and I have a car again after 3 months. This crap makes me never want to buy another combustion engine car again. I think I'll keep the BRZ forever and when Lotus or another brand makes an electric sports car that's under $100k, then I'll pick one of those up. It's been tempting to put money down on an Emira, yes I know it's still ICE, but don't want to blow all my money on a monthly car payment when I have a house to pay off first. |
Got the P0171 code again. Cleared the code and drove around a couple days and attempted to take it threw DEQ but engine light came on while waiting in line. Cleared the code while in line but the guy asked if I had my battery replaced as there wasn't enough O2 and other data stored. I just said yes as I didn't want to explain anything. It was working fine for about 4 months. Guess I'm taking it back to the shop to have them go through it again... :mad0259: :bonk:
Got my car back today. This time only just over 2 weeks which was much better than months. This time the vacuum leak was in the superchargers coolant hose fitting on the back of the supercharger. The o-ring and seal worn out and was leaking air and a little coolant. Removing the supercharger intake manifold is expensive/labor intensive so this little stuff isn't cheap when it needs to be removed. Almost $1k in labor. Thankfully they said they won't charge for the parts. They also replaced the supercharger to manifold gasket again just so it was a new one instead of reusing the old one even though it was pretty new. Hopefully no more vacuum leaks for many years to come. :mad0259:
Car is at 91805 miles. Now to get new registration stickers now that I can pass emissions since no engine code. |
My car is at it's 12th year anniversary from August 2012. I'm at 104k miles. No new parts but more underbody scraps and broken clips and damaged bolt heads from being so low.
This year August 2024, I had to have the gas filler hose replaced as it was delaminating on the inside and wasn't letting me hose the trigger at the gas pump. $100 part cost me $1400 for the shop to get to it and replace it. :( I tried to figure out the issue myself but the cheap Amazon wire camera sucked and missed the delamination as the quality sucked so bad on the light and camera. |
| All times are GMT -4. The time now is 12:59 AM. |
User Alert System provided by
