-   -   Coyoda Turbo Kit Thread. (https://www.ft86club.com/forums/showthread.php?t=115275)
Stimmed 09-21-2017 09:04 PM
Awesome pics!.
I have seen the kits in parts before but never all together like that lol. (Had mine installed through Coyoda)
What car did you drive with the big turbo on it Tonys? And I agree I am running the biggest turbo they offer and I do not find it laggy at all compared to the previous one I had on there with a smaller turbo and longer piping.
Hags86 09-21-2017 11:46 PM
I test drove the Coyoda test mule with the FP Black turbo. I ended up buying the smaller 28xx turbo as I'm not going to build the bottom end right now. In a few years when the car is retired from daily duties I'll build the engine and put the larger turbo on then.
Stimmed 09-22-2017 12:37 AM
Yup the FP black is awesome. I was lucky enough to be the test pilot for there kit with that turbo and it worked out perfectly.
You will love the kit :) Who is Tuning it?
Hags86 09-22-2017 08:56 AM
Melbourne Performance Centre. I have a Motec M150 ECU to go with it and they are the goto guys for Motec in Melbourne.
Bodalenko 09-23-2017 06:37 PM
You're obviously confident and competent with the install but the distance from Melbourne, I live here as well, to either Yoda or Tony is one of the concerns I have with purchasing this kit, as brilliant as it appears to be. Quick and reasonably close support is very important, and it's a long way if you need some assistance with those little things you just know are going to pop up regardless of how sorted the kit is.
Just wondering if Melbourne Perfomance Centre are the agents for the kit in Melbourne?
Good luck with the install. Does look remarkably straight forward.
Yoshoobaroo 08-05-2018 03:50 PM
Any update on the production status of the Coyoda kit? I keep seeing a red coyoda branded 86 in Alan's Skidfactory videos, so I guess they're still testing?
johl 08-05-2018 07:21 PM
I spoke to alan at the start of the year and he said he had 2 kits left in stock. I’m sure they would have made more once those sold. There are quite a few of these kits around where I live, but I’m pretty close to his work shop
Mike_ZN6 05-13-2020 07:47 PM
I can't find a website to check out this kit. Does anyone have a link for Coyoda?
johl 05-19-2020 05:02 AM
I’m not sure if it is still in production.
There is a modified kit using a Garrett g-25-660 making 400kw. It has gone through a full build and raised compression to 13.5-1 and is run by a motec ecu with massive direct injector work
sato 05-24-2020 02:32 PM
There is a modified kit using a Garrett g-30 making 400kw. It has gone through a full build and raised compression to 13.5-1 and is run by a motec ecu with massive direct injector work
Link, link!
Sent from my Pixel 2 using Tapatalk
johl 05-26-2020 04:09 AM
If you search for an australian workshop called “the 86 shop” they posted it on the 13th of May 2020. No link to a build thread but you can find the owner through the fb page of you have any questions
sato 05-30-2020 08:35 AM
Found it. Thanks...again, impressive build
