-   -   F1point4's Asphalt FR-S 6MT (https://www.ft86club.com/forums/showthread.php?t=8295)
Draco-REX 08-16-2012 10:18 AM
Originally Posted by F1point4 (Post 383275)
Haha. I don't have my own garage so I have to carry my gear to one of my work sites. Need to keep it minimum. In the end, jacks and stands allow me to do more than ramps do, that's all.
Ahh, makes sense.
Phaedrus29 08-24-2012 05:23 PM
Originally Posted by F1point4 (Post 383141)
Several things I could do to correct the situation
- get a floor jack that could lift higher
- get stands that are smaller (I have tall stands)
- find a thicker block of wood to place between the jack and frame (could be unsafe)
I think I'd try a thicker block of wood next time.
As for sliding the jack under the center jack points, mine doesn't fit either in its resting position. I had to pump and hold the handle all the way down for the jack to clear the front lip. Even in this position I probably had like 1/2" to 1" of space between the jack and the front lip. This is probably why I wont buy a larger floor jack.
If my car was lowered I'm afraid I'd have to buy one of those long flat jacks to lift it.
F1point4
I ended up getting this jack from Harbor Freight: http://www.harborfreight.com/2-ton-l...ump-68051.html
Because the front jack point is back a bit, the raised part of the jack gets much too close to the front bumper for my liking. Especially if the car is lowered, I can't imagine this jack will work. Maybe this one would have been a better option???:
http://www.harborfreight.com/2-ton-l...ump-68050.html
F1point4 08-24-2012 05:28 PM
Got the JDM Side Markers on. Did a DIY writeup here
http://www.ft86club.com/forums/showthread.php?t=15560
It looks so much better now that all the lights match
http://farm9.staticflickr.com/8441/7...1f7f3f25_c.jpg
20120824-LolaClearSideMarker-01 by VictorN07, on Flickr
http://farm9.staticflickr.com/8306/7...6cf03b36_c.jpg
20120824-LolaClearSideMarker-33 by VictorN07, on Flickr
http://farm8.staticflickr.com/7268/7...3430c09a_c.jpg
20120824-LolaClearSideMarker-31 by VictorN07, on Flickr
F1point4 08-24-2012 05:34 PM
Agreed, The lip hits the handle on mine so I have to insert the jack with the handle pushed all the way down. When this one breaks, I'll get the super flat jack you listed.
Phaedrus29 08-24-2012 08:16 PM
It's not so much the handle for me but rather this part:
http://i171.photobucket.com/albums/u...mage_12369.jpg
UPDATE: I exchanged that jack for this one (http://www.harborfreight.com/2-ton-l...ump-68050.html), and I can report that this one works perfectly with no fitment issues. The Harbor Freight 3ton jack stands also do a nice job of supporting the car on both sides of the pinch welds...they clear the whole pinch weld.
F1point4 08-30-2012 08:06 PM
JDM Mirror installed.
DIY here http://www.ft86club.com/forums/showthread.php?t=16123
http://farm9.staticflickr.com/8169/7...bb4a659c_c.jpg
20120830-LolaJDMMirror-00 by VictorN07, on Flickr
http://farm9.staticflickr.com/8036/7...eb2ed518_c.jpg
20120830-LolaJDMMirror-18 by VictorN07, on Flickr
F1point4 09-03-2012 12:38 AM
Back for more. http://www.ft86club.com/forums/showthread.php?t=16300
http://farm9.staticflickr.com/8303/7...4fce4b0a_c.jpg
20120831-LolaBlackVue400DIY-01 by VictorN07, on Flickr
On a side note I am currently averaging 29 MPG with 2500 miles on the clock. I am sadface because no matter how careful I am there is swirl marks in my paint. However I suspect that the body shop I used put some on while attempting to clean my car for repair. Guess I will take this as an opportunity to learn paint correction.
F1point4 09-15-2012 04:49 PM
Did some more interior changes recently. Here is a custom engraved Flossy Shift Knob. Swapped it to save the stock knob from getting marred from use.
It weighs considerably more than the OEM shift knob and makes shifts a little smoother. I believe MTF swap is needed for ultimate smoothness. Install was painful. It took me 20 minutes to screw it on so the picture was aligned correctly.
You already know I like to take photos, artsy photos. Stock knob
http://farm9.staticflickr.com/8319/7...5e47600d_c.jpg
20120831-FlossyShiftKnob-3 by VictorN07, on Flickr
Comparison
http://farm9.staticflickr.com/8037/7...d3d98034_c.jpg
20120831-FlossyShiftKnob-4 by VictorN07, on Flickr
Final product
http://farm9.staticflickr.com/8438/7...344e9051_c.jpg
20120831-FlossyShiftKnob-5 by VictorN07, on Flickr
F1point4 09-15-2012 04:58 PM
My legs don't bend the way necessary for heel toe. Decided to swap out for the Sullivan Racing Products Racing Pedals. The quality is quite good and it brings the gas pedal closer to the brake. SRP makes a gas pedal only option that matches OEM fairly close, but I opted for the entire set.
Must slow down with the mods. Staying true to the hellafunctional motto.
Whole set. Milled out of aluminium.
http://farm9.staticflickr.com/8040/7...3e059271_c.jpg
20120914-SRP Racing Pedals-1 by VictorN07, on Flickr
Grid pattern. Not anodized. The brake, clutch, and dead pedal have this texture.
http://farm9.staticflickr.com/8180/7...2c105c74_c.jpg
20120914-SRP Racing Pedals-6 by VictorN07, on Flickr
The gas pedal is smooth so your foot can slide
http://farm9.staticflickr.com/8312/7...c04388e1_c.jpg
20120914-SRP Racing Pedals-7 by VictorN07, on Flickr
Add the pedals have this finish on the back
http://farm9.staticflickr.com/8310/7...df87c6d5_c.jpg
20120914-SRP Racing Pedals-4 by VictorN07, on Flickr
Installed!
http://farm9.staticflickr.com/8297/7...1e16b6ae_c.jpg
20120915-SRP Racing Pedals-9 by VictorN07, on Flickr
http://farm9.staticflickr.com/8314/7...e3ea6951_c.jpg
20120915-SRP Racing Pedals-11 by VictorN07, on Flickr
F1point4 09-15-2012 05:29 PM
Here are some observations from the racing pedal install.
My car was undriveable for a while
http://farm9.staticflickr.com/8456/7...ab72f4af_c.jpg
20120915-SRP Racing Pedals-12 by VictorN07, on Flickr
Held on tight
http://farm9.staticflickr.com/8033/7...06301aa5_c.jpg
20120915-SRP Racing Pedals-13 by VictorN07, on Flickr
Covered removed and my chosen drill points
http://farm9.staticflickr.com/8301/7...40498da0_c.jpg
20120915-SRP Racing Pedals-14 by VictorN07, on Flickr
Comparison between stock gas pedal and new gas pedal
http://farm9.staticflickr.com/8037/7...1eecd8ec_c.jpg
20120915-SRP Racing Pedals-15 by VictorN07, on Flickr
It's not a perfect fit. I'm okay with it though
http://farm9.staticflickr.com/8302/7...91b42769_c.jpg
20120915-SRP Racing Pedals-16 by VictorN07, on Flickr
Dead Pedal was a bitch. I ended up cutting a hole in the carpet.
http://farm9.staticflickr.com/8436/7...7d350130_c.jpg
20120915-SRP Racing Pedals-17 by VictorN07, on Flickr
Shows how much carpet I took out.
http://farm9.staticflickr.com/8449/7...1f8307f7_c.jpg
20120915-SRP Racing Pedals-19 by VictorN07, on Flickr
Clips
http://farm9.staticflickr.com/8311/7...c7bfd5d0_c.jpg
20120915-SRP Racing Pedals-18 by VictorN07, on Flickr
There was foam behind the pedal. I took that out.
http://farm9.staticflickr.com/8441/7...88bbc8f7_c.jpg
20120915-SRP Racing Pedals-20 by VictorN07, on Flickr
Full fit.
http://farm9.staticflickr.com/8320/7...6cd04489_c.jpg
20120915-SRP Racing Pedals-21 by VictorN07, on Flickr
Instead of leaving the foam there, I decided to remove it. The mounting surface for the dead pedal is not rubber, but metal. It was also not black so I ended up using black racing tape so it grey wouldn't show through the pedal.
The kit included 8 self tapping screws and 6 bolts with locking nuts. The gas pedal was plastic so the self tapping screws were perfect for that. I used 4. The brake and clutch pedals were steel so I ended up using the nuts and bolts for those. Used 3 each.
I knew ahead of time I wouldn't be able to use the nuts and bolts for the dead pedal since I can't reach behind. When I found out the mounting surface was metal I knew the self tapping screws provided aren't appropriate but I made them work. The instructions said to drill a 1/16" hole for the dead pedal but the screws wouldn't work unless until I bored out a 7/64" hole. The self tapping screws are also fairly short. Think 1/2". If I used the foam the screws would not reach the metal.
Not aiming to bash SRP. It is a good product. Just wanted to raise awareness.
post_break 09-15-2012 05:30 PM
What's the cost on those pedals? In my opinion the brake pedal is about an inch too far right, and the gas as well. Way too close to the wall your leg rests up against.
F1point4 09-15-2012 05:36 PM
116 with the coupon code "ft86club". They have a black anodized option. I with you on alignment of the stock pedals. The picture shows that plastic piece next to the gas pedal all scuffed up.
I do like that my shoes definitely grip to the brake and clutch with the new pedals' grid pattern.
F1point4 09-23-2012 12:01 AM
http://www.ft86club.com/forums/showp...9&postcount=68
Originally Posted by F1point4 (Post 455269)
I like technical data. I like photography. Here is a thread about both. Enjoy
Goals:
Stay Functional
Max Grip
Lower weight than OEM combo.
Went with:
WedsSport TC105N 17x9 +35 square setup (Thanks @RavSpec)
Hubcentric Rings 65mm to 56mm
Dunlop Direzza Sport Z1 Star Spec 245/40R17 (Thanks Discount Tire)
Stock TPMS sensors
Stock Suspension
Factory Geometry settings
The 17x9 +35 in a 5x100 setup is a limited run for the 86. Thus official weight is unlisted on the Weds website. Here is what my human scale told me.
http://farm9.staticflickr.com/8449/8...7f542e03_c.jpg
20120921-TC105N_Z1StarSpec-17 by VictorN07, on Flickr
Sports Utility Vehicle. I don't have a picture of when I had the OEM wheels in my car, but they fit dammit
http://farm9.staticflickr.com/8461/8...5949b366_c.jpg
20120921-TC105N_Z1StarSpec-2 by VictorN07, on Flickr
The setup. Discount Tire was cool about letting me be in the garage and learning about what they do. I was super happy to be there cause they almost put on my wheels with impact tools. Nope!
http://farm9.staticflickr.com/8300/8...811e3797_c.jpg
20120921-TC105N_Z1StarSpec-16 by VictorN07, on Flickr
Discount Tire told me they'd dismount the OEM tire and pull the TPMS sensor to transfer to the new setup as part of the deal. Here is a picture of the sensor. It is attached to the valve stem.
http://farm9.staticflickr.com/8449/8...d59ba873_c.jpg
20120921-TC105N_Z1StarSpec-14 by VictorN07, on Flickr
http://farm9.staticflickr.com/8029/8...782feaf8_c.jpg
20120921-TC105N_Z1StarSpec-15 by VictorN07, on Flickr
I don't know how calibrated my scale was. What was important to me was the difference in weight. Stock wheels are 40.6 lbs. TC105N with Star Specs were 42.4. Damn.... Anyway it is pretty good for what I'm putting on.
http://farm9.staticflickr.com/8452/8...c03f6a53_c.jpg
20120921-TC105N_Z1StarSpec-18 by VictorN07, on Flickr
http://farm9.staticflickr.com/8315/8...9b89b481_c.jpg
20120921-TC105N_Z1StarSpec-19 by VictorN07, on Flickr
Thoughts so far
I drove 200 miles so far on this setup. Haven't taken it to a track yet. It definitely gives me more confidence in what I'm doing. Just grip for miles. Since the wheels now weigh more, I can definitely feel the sluggishness at start. Brakes fine. I figure a headerback exhaust may balance out the unsprung weight gain. The Star Specs do have a different audible characteristic. I find the OEM Michelins to grumble and have a deeper tone. These Star Specs definitely howl, but it's not annoying. I could probably fix some of that with sound deadener. For rubbing, I believe that other people threw on 17x9 +42s and they fit fine so the +35 offset should be good. I haven't felt anything bad in my driving so far.
In terms of looks, the rear looks great. The front sticks out a little bit as the pictures below show. However, stance. I got plenty of that now. Now for photos; please enjoy them as much as I did taking them.
http://farm9.staticflickr.com/8029/8...bb0526a6_c.jpg
20120922-TC105N_Z1StarSpec-16-Edit by VictorN07, on Flickr
http://farm9.staticflickr.com/8317/8...4bda9c16_c.jpg
20120922-TC105N_Z1StarSpec-1 by VictorN07, on Flickr
http://farm9.staticflickr.com/8302/8...99c87a22_c.jpg
20120922-TC105N_Z1StarSpec-22-Edit by VictorN07, on Flickr
Front
http://farm9.staticflickr.com/8037/8...44d365c6_c.jpg
20120922-TC105N_Z1StarSpec-30 by VictorN07, on Flickr
Rear
http://farm9.staticflickr.com/8174/8...b0c484fb_c.jpg
20120922-TC105N_Z1StarSpec-25 by VictorN07, on Flickr
http://farm9.staticflickr.com/8438/8...e0679651_c.jpg
20120922-TC105N_Z1StarSpec-28 by VictorN07, on Flickr
http://farm9.staticflickr.com/8181/8...f06eb9a7_c.jpg
20120922-TC105N_Z1StarSpec-33-Edit by VictorN07, on Flickr
http://farm9.staticflickr.com/8320/8...9243f2ff_c.jpg
20120922-TC105N_Z1StarSpec-32-Edit by VictorN07, on Flickr
http://farm9.staticflickr.com/8439/8...9efb9e02_c.jpg
20120922-TC105N_Z1StarSpec-37-Edit by VictorN07, on Flickr
http://farm9.staticflickr.com/8450/8...1d85a497_c.jpg
20120922-TC105N_Z1StarSpec-41 by VictorN07, on Flickr
Questions I have
If anyone would like to help me answer these quick questions, I'd appreciate it greatly
* Since my wheels stick out, I have to add negative camber if I lower it?
* What is the daily driving PSI for this setup? Discount Tire said 35psi, but I have no experience with aftermarket wheels.
* Will a headerback gain balance out the unsprung weight gain? I was just guessing up there.
F1point4 09-23-2012 01:59 PM
Rally Armor Mud Flaps Review
Ordered direct from Rally Armor. They shipped USPS Priority from NY. Wasn't expecting it, but it came in two days. And on it went this morning.
I didn't get pictures of the flaps themselves. They are approximately 1/8" thick, made of urethane, have a shiny finish. They install into the factory clip locations so there isn't any drilling required. Remove the stock clips, install the bracket and plastic tabs for the screws and then screw the flap into place. The are "adjustable width" so they can slide in and out depending on preference. If you do not want to see the Rally Armor logo, you can turn the flaps over and switch sides.
Definitely have the right tools or be able to remove the wheels. I opted to not remove the wheels so I turned the screws using vice grips.
Other than the fact that the screws are silver, the flaps compliment the extra width from the 17x9 245 wheels. Some may say ugly, I think they look great and are hellafunctional. For pure aesthetics, I probably would not have gone with it if I didn't go with wide wheels. I think the color goes well with Asphalt/DGM too.
I brought my Nikon sans memory card so iPhone has to do. Now on to the pictures
Side shot:
http://farm9.staticflickr.com/8038/8...139b2d00_c.jpg
21020923-RallyArmorMudGaurd-01 by VictorN07, on Flickr
Front 3/4:
http://farm9.staticflickr.com/8297/8...58065380_c.jpg
21020923-RallyArmorMudGaurd-08 by VictorN07, on Flickr
Rear 3/4
http://farm9.staticflickr.com/8174/8...cc21a46d_c.jpg
21020923-RallyArmorMudGaurd-07 by VictorN07, on Flickr
http://farm9.staticflickr.com/8304/8...864556ba_c.jpg
21020923-RallyArmorMudGaurd-02 by VictorN07, on Flickr
Rear Stance
http://farm9.staticflickr.com/8440/8...e6fc57e8_c.jpg
21020923-RallyArmorMudGaurd-04 by VictorN07, on Flickr
Rear ISO View. This is the flap pulled all the way out. Lines up with the wheel very well. I can slide it in about 1/2".
http://farm9.staticflickr.com/8448/8...5d0475db_c.jpg
21020923-RallyArmorMudGaurd-03 by VictorN07, on Flickr
Front ISO View. I had the flap all the way in in the front. As you can sort of see, it's not flush with the wheel, but I think all the way out would look off.
http://farm9.staticflickr.com/8035/8...6ac02b0d_c.jpg
21020923-RallyArmorMudGaurd-06 by VictorN07, on Flickr
Front installation. Held on with screws and washers. Wish the screws were black. Four in the front. Note the shinyness.
http://farm9.staticflickr.com/8304/8...edc9415b_c.jpg
21020923-RallyArmorMudGaurd-09 by VictorN07, on Flickr
Rear Installation. Three in the back. It doesn't come all the way up to the wheel well liner, but you cannot see the gap from the rear, even if you bend down.
http://farm9.staticflickr.com/8303/8...781ace42_c.jpg
21020923-RallyArmorMudGaurd-10 by VictorN07, on Flickr
