A. they have got to find it, unlikely unless the pull your ROM and Analise the actual hex code they wont know, as the calid in techstream will be the same as a stock calid for a tuned ROM. B. If you have the ability to flash back to 100% stock ROM then their is sod all chance of them finding anything and even if they find the mythical flash counter (which I have yet to find in techstream) then all they have is a stock ROM and no proof anything else was in there. Unlike hardware mods which are in plain sight and difficult/time consuming to swap out for service. |
I already own the header and not spending $500+ on a tune. I'll be using a catalytic converter of some sort to get it right.
Having a bung welded after your second cat, extending the wiring and hoping it works seems much, much more difficult/expensive. |
See post #28 and #30
The second O2 sensor is literally only there to ensure your cat is working, this reading is not used for any engine management purposes. |
Though, I already bought the bung and o2 sensor extension cable. So as long as the welding the bung is cheap that will be my cheapest route at this point. |
As far as getting a bung welded in it's usually $10-20 depending on if on the car or not. |
Another member has done this with success for 5k+ miles
Btw, there will be a delay since you are placing it further back. Just because some moron done it for 5K miles doesn't mean he knows what he is doing. |
| All times are GMT -4. The time now is 08:16 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2025 DragonByte Technologies Ltd.
