-   -   Disable high Rev cold start (https://www.ft86club.com/forums/showthread.php?t=55676)
Td-d 03-10-2014 07:25 AM
I still need to implement these two tables. Will try today.
Sent from my iPad using Tapatalk HD
Td-d 03-10-2014 10:01 AM
Ok, I've implemented into ZA1JA01C, download this definition:
https://raw.github.com/TD-D/SubaruDe...R_ZA1JA01C.xml
They are in the Mass Airflow / Engine Load section.
http://i990.photobucket.com/albums/a...ps7ce2d722.png
Td-d 03-10-2014 10:20 AM
@troek - what's your CAL id?
Nevermind, I've added to ZA1JA01A, here:
https://raw.github.com/TD-D/SubaruDe...R_ZA1JA01A.xml
Td-d 03-10-2014 11:48 AM
Ok, I've added to all roms on my Github repository:
https://github.com/TD-D/SubaruDefs/t.../RomRaider/ecu
Remember, if you are downloading from here, make sure that you click on "raw" to get the actual XML (otherwise you will download an html page!)
Kodename47 03-10-2014 01:03 PM
Originally Posted by troek (Post 1586149)
What values have u tried?
EDIT: I cant seem to find that table in RomRaider.
I've made all rows the same using the lower ones as a template.
troek 03-10-2014 03:37 PM
so you have all rows reading 8, 7, 7, 5, 5, etc?
awesome, thanks man. very helpful! did you add any other tables?
Td-d 03-10-2014 03:53 PM
Not at this stage - but if there's anything specific you want, let me know.
troek 03-11-2014 04:10 AM
yes this definitely made a difference, now im not afraid to start my car at 5 am lol. thanks. im runing all tables the same in the maf correction after start, 1400 rpm target idle, and reduced to -8 timing in the post start table. its a pretty significant change.
Td-d 03-11-2014 06:29 AM
:thumbsup:
mad_sb 03-11-2014 07:46 AM
Originally Posted by Td-d (Post 1589854)
:thumbsup:
Any idea on the table logic for the post start maf correction? As in what the table actually does? Initially I thought it was just a post start reference or target value for maf g/s.
If this is a reference (initial estimated maf reading used for fueling right after it catches) then it would not make sense for this table to affect the cold start beyond the first second or so of the cold start.
If, on the other hand, it is a maf target table used during cold start then it makes perfect sense and I would assume the ecu adjusts throttle plate angle to get the desired air flow. On 21*C cold start i see 18 - 19 g/s during the high idle cold start.
Td-d 03-11-2014 08:28 AM
I'll dig into the logic but I don't believe it's a reference - that was already available as the post start airflow reference and the load reference tables.
Td-d 03-11-2014 12:02 PM
It's definitely an adder to MAF.
regal 03-12-2014 07:23 AM
My car never idles over 900 rpm even if under 10F overnight. I'm hopefully about to buy BRZ edit, perhaps I could send my bin for those more familiar with these cars to compar (mine is a fall 2012 dealer flash.)
Td-d 03-12-2014 07:26 AM
You won't have these tables in BRZedit (yet, I'm sure they'll get copied soon enough ;) )
regal 03-12-2014 07:31 AM
Thanks what about romraider?
Td-d 03-12-2014 07:38 AM
Yup, I've implemented across all roms. Yours is probably ZA1JA00C.
troek 03-12-2014 08:02 AM
are you invovled with romraider or are you just some random helpful dude?
regal 03-12-2014 08:07 AM
Nope the dealer won't flash that on 2012 built cars, mine's ZA1JA00C.
Td-d 03-12-2014 08:16 AM
Chuckle... when you say involved, not with the development no (there are others that carry that torch), but I guess you could say I've mostly taken over the role of creating definitions for the past two years or so. I've also been actively involved in digging out features that were available on other platforms (like COBB's AP) and implementing them for open source.
Td-d 03-12-2014 08:17 AM
? As I said, ZA1JA00C. In any case - the tables are available for this rom, yes.
regal 03-12-2014 08:20 AM
Sorry I've got to get bifocals, you know quite a bit about these cars.
What is your opinion on the stability/risk with ECUflash as is stands today?
Td-d 03-12-2014 08:53 AM
No worries, 2 / 3 more years, and I'm at that age as well sadly!
There's quite a number of people who've used it successfully on here - also, Mikey contacted me last week, they are about to issue a new release, which I'm hoping has implemented the proprietary Ecuflash kernel. This will definitely make flashing easier, and faster.
It's not for everybody I guess, but I like the freedom that a completely open platform offers.
mad_sb 03-12-2014 09:00 AM
Don't count on it. He has not updated defs in a very long time. In fact I would not ever expect another update from epifan.
mad_sb 03-12-2014 09:03 AM
The dealer can only flash factory roms so yours is likely already available for download etc. I'm starting to think they flashed the wrong image in your car. I can't fathom how the cold start cold be so broken without throwing any codes.
mad_sb 03-12-2014 09:04 AM
Thanks man, so now the question becomes is it used to create a target load / airflow value or is it just for fueling. I can play around with it a bit this weekend. Should be easy enough to figure out now.
86-tundra 03-24-2014 11:23 AM
Hey troek do you mind posting a screenshot of the tables you changed? That would be awesome.
-someone else who care about their neighbors :lol:
troek 03-24-2014 03:31 PM
im out the door to work right now, but ill take some shots when i get home tonight. if you wanter lower idle speed adjust idle tables A and B in the 1700 values to 1400 for example. im trying my post start idle ignition timing at 0 right now, and it seems to not have any benefit, ill probalby go back to -8 next time i flash, just to be on the safe side as we cant yet adjust the retarded injection.
UPDATED:
http://i132.photobucket.com/albums/q...pseeb57ee4.jpg
86-tundra 03-27-2014 09:19 PM
UPDATED:
Hey there
Just getting to this now. Any chance you could post a LITTLE higher res photo? Hard to read the values :) Thanks man
nvm. Think I got it
-8.05 for all inigntion timing post start
Copy rows values in rows 3-8 to rows 1-2 for maf correction after start (in gear and neutral) :cheers:
troek 03-27-2014 11:45 PM
sorry, i didnt realize it was so blurry. its actually 0, but -8 dosnt sound any louder, so i think its a safer bet since its thats much closer to factory. and correct, for the maf just copy the values from the lower rows.
FRS_FIEND 03-28-2014 01:05 AM
people are so technical :] lol (i say that in a great way). Just tap the accelerator right after you start and it will idle normal and it wont be doing high revs and let it sit till it gets to idle operating temp. TA-DA! LMAO of course i have no idea if thats bad but it shouldnt be as long as you wait a lil longer for the warming up. no i dont do this everyday its just something i stumbled upon. One day before work (tired as hell) i when to start my frs in the garage and reversed her outside as if i was going to work ( i was still in my boxers, yeah that tired lol) then realized i still needed to get dressed for work so i stopped on my driveway and let it warm up and it was normal idle not the high revving cold start. lol
xjohnx 03-28-2014 08:17 AM
Originally Posted by trevorovert (Post 1631342)
Hey there
nvm. Think I got it
i'm not OP, but here you go. click to enlarge, or just go directly here: http://i.imgur.com/ZBR0Bl6.jpg
http://i.imgur.com/djsa75Y.gif
troek 03-28-2014 07:54 PM
hahahahaha your gif made my day
Migero86 03-29-2014 09:14 AM
grrrr... romraider is telling me those xml files are invalid for the ECU def for A00C....
LMAO... ooooops... nevermind... I clearly need more coffee NOW!
Migero86 03-29-2014 09:41 AM
Got the file working in XML format however when I open a table I get this error...
Edit: OK... some how... I rebooted my PC and now it works no issues.... wtf!
Td-d 03-29-2014 03:08 PM
Don't worry about that, fix the checksum with Ecuflash, or OFT, and it's fine.
cruizin01 03-29-2014 03:56 PM
I know OFT will fix the file but when it error's its not editable... What am I not understanding?
Td-d 03-29-2014 04:05 PM
What that message means is that editing of the table "Checksum 2" is disabled, the other tables will all be editable.
cruizin01 03-29-2014 04:28 PM
Yup, i'm an idiot. Thx
Sent from my Galaxy Nexus using Tapatalk
EDIT:
Just reflashed the car after adjusting the above maps. Works GREAT! Its 33*F here, on a cold start the car fired right up with ~1 sec of loudness then calmed right down. Still idling at ~1400 but very minimal noise. (full exhaust)
Thanks!
cruizin01 03-31-2014 10:22 AM
Got a cel with a p050b code this morning. Fail.
Guess this needs a little work.
