-   -   Final Drive gears?? (https://www.ft86club.com/forums/showthread.php?t=88945)
wparsons 05-26-2015 03:37 PM
Originally Posted by KoolBRZ (Post 2262619)
Read before you reply, you ASSumer. I said it doesn't change the gears themselves. If you would take your blinders off, you would see what I mean. I'm talking about the change in ratios between the engine, the source of power, and the destination, the tires on the road. I clearly spelled out the change in redline peaks per gear when changing FD's. You just ignored that and spewed idiotic insults because you thought I was just talking about the gears in the transmission itself. If I was just talking about gear ratios in the transmission itself, why show engine RPM's? I've been talking about the overall ratios between the engine and the tires.
Bolded part shows you don't actually understand what you're talking about. Why on earth are you including different rpm's for different scenarios? If you want to compare FD's, the only variable should be the FD. Not the FD, and RPM.
Talking about blinders, if you had actually read my post, you would've seen the part about how close ratio with tall FD (same overall ratio in 4th) and wide ratio with short FD will be very different to drive, and would be used for different reasons even if one gear (say 4th) had the same overall ratio (gear ratio * final drive ratio).
Running a shorter final drive doesn't make the internal ratios any closer, and the RPM drop between shifts stays the same, the only thing that changes is how fast you go in each gear. Yes you spend less time in each gear with a shorter FD, but that does not mean it's a close ratio at all.
Another gross over simplification of yours.
Ultramaroon 05-26-2015 04:13 PM
Originally Posted by KoolBRZ (Post 2262809)
Who said I was talking about gear ratios? I'm talking about the ratios between the engine and the tires. I'm also not talking about torque, but about mechanical advantage between components. Check out the links I posted before you assume I'm providing misinformation. Your negative assumptions only hurt yourself. What help are you with your criticisms? I provided helpful links. While you can only criticize in a vain attempt to make yourself look better. The OP wants help, not critical, self-serving, negative crap.
This is not personal. It's about accuracy. So you have links. That's nice. Your interpretation/summary of the information is flawed. Get it right and no one will pile on you. Consider it informal peer review.
Nigelr32 05-26-2015 05:27 PM
Thanks for all the replies guys. Looks like there's some passion here??
I forgot to mention that I have an Ali prop shaft from Driveshaft shop, uprated driveshafts from driveshaft shop and a Cusco 2 way LSD.
I can see the benefit in a higher FD for launches, but as already mentioned, there will be a benefit in a lower FD to hold the gears for longer. Is the stock gears capable of 600hp launches??
humfrz 05-26-2015 07:17 PM
Originally Posted by Ultramaroon (Post 2262999)
................. Consider it informal peer review.
That's good ! ....... "I don't care who you are" ....... :D
humfrz
Ultramaroon 05-26-2015 09:33 PM
humfrz
While I did admit to "becoming personally offended," I maintain, with respect to content, it's not personal.
There's a difference, right? I hope... o.O :barf:
cdrazic93 05-26-2015 09:50 PM
Nooooooo. No. Nope. Whole lotta nope in that.
brianhj 05-27-2015 09:06 PM
Just curious, what are people doing as far as the transmission is concerned when building the engine (300+ ft lbs)? Fitting a v160 to it? Cuz I know the stock transmission doesn't handle that much torque well. And I heard it gets insanely expensive to get a stronger gearset for the stock transmission (according to fbm)
wparsons 05-28-2015 08:17 AM
How much torque the gearbox will (happily) take depends on how you drive it. If you're going to be launching hard and slamming shifts it'll take a lot less power than if you're doing highway pulls with more gentle shifts.
fika84 05-28-2015 09:31 AM
There are lots of threads talking about this specifically if you search for them. All options are expensive.
http://www.ft86club.com/forums/showthread.php?t=63053
http://www.ft86club.com/forums/showthread.php?p=2257899
I know there's more around here too talking about it.
brianhj 05-28-2015 10:12 AM
Cool.
Nigelr32 05-29-2015 05:31 AM
Thanks for those positive words ha ha.
When I said Gears, I meant the Diff gears. Is this what you are referring to?
As for the transmission, I will be using Samsonas or Quaife?
cdrazic93 05-29-2015 06:33 AM
I only know Quaife. The diff gear is relatively strong, its a derivation from the supra diff.
Nigelr32 08-14-2015 02:10 PM
Thanks for all the replies on here guys.
I have kept my stock gears and also bought a 4.55:1 set. There is also going to be a little Samsonas in my life shortly.. I went for the Option 3 gears with the 0.962 drop gears.
I can't wait to drive this car!!
stockysnail 08-14-2015 03:43 PM
:popcorn:
This was a good lunch break read.
:barf:
