You've gotten some good tips in this thread. Are you starting to catch on what it is you need to practice? I learned how to start on a steep slope by watching my father do it in San Francisco (on streets like the one that goes up to Lombard like someone here mentioned lol). Use the handbrake to hold the car. Carefully let out the clutch and get on the gas til just past the engagement point and you can feel the car fighting the handbrake. Then start slowly easing off the handbrake. So you're balancing three things at once: clutch, gas, handbrake. If you can, find a *slightly* sloped empty street to practice, then move on to steeper slopes. That would be the ideal case to learn; unfortunately the world isn't really set up like that so you have to do the best you can lol :) |
It will come with time. I remember pulling out of certain parking lots here in Houston was terrifying at first. Learning exactly where the clutch grab point is and stopping being afraid of hills kind of go hand and hand.
I just hold the brake with my right and release the clutch until I feel it grab just enough to take the engine rpm down without stalling, then I quickly slide my foot off the brake and onto the gas and accelerate normally. I have never tried the handbrake technique because I haven't needed it here in Houston. |
I used to instruct drivers in South Africa, where most people drive manuals, and a hill start is actually part of your test (along with alleyway and parallel parking) on a controlled course at the DMV. ANY rollback is an automatic fail, as it is unsafe and you are not in control of your car. Oh, and people talking about burning out your clutch? :bellyroll: If you are concerned about that on a hill start, your revs are far too high! Practice makes perfect, and the above method is definitely the textbook method. Flame suit on! |
you could try using the e brake method
I just 'catch' the car with the clutch (after letting go of the brake) then add RPMs. usually the amount you slip the clutch isn't any more than a normal start on level ground.
I was never told to try the e brake thing when I was learning to drive (I learned on stick). Add to that that it was a truck with a foot ebrake I said forget learning that. So eventually I just got used to timing the release of the brake and clutch and getting on the gas a bit as the clutch starts to engage. When I was starting out I used to look at the revs to see if they were dropping that's when I knew to start adding gas. Just have to practice, I used to practice (and from time to time still do) in our driveway since its a pretty decent incline
I get where you're trying to go with this, but NO ONE should rely on this tidbit of information. :slap: |
Find summer a job in San Francisco or Seattle downtown which includes free parking. |
| All times are GMT -4. The time now is 04:22 AM. |
User Alert System provided by
