-   -   Wheel specs for Rocket Bunny Fenders (https://www.ft86club.com/forums/showthread.php?t=20429)
Limitless_BRZ 04-09-2021 11:03 PM
im thinking of ordering a set of wheels. but before i order, does anyone run this size
F: 18x9.5 -3,
R: 18x10.5 -26
on the 2017+ brembo brakes ?
oBradyG 03-23-2022 04:09 AM
What were the specs for these wheels, and any spacers used? This is my ideal setup
Zer0 08-10-2022 09:06 PM
Square setup
18x11 et33 what do you think of these specs ran square no spacers? Tires 315 30 18
DustinS 09-02-2022 10:14 AM
18x10.5 et22 up front w/ 10mm conversion spacer. I have since switched to 5x114.3 hubs and run a 5mm spacer.
18x10.5 et15 rear w/ 25mm spacer.
285/30R18 square
If I remember correctly, 18x11 et22 w/a 315/30 should fit flush-ish. Still a lot of work needed for turning clearance.
