There is no lock out for 1st, but I'm pretty sure there is no syncro for 1st either. So even with the clutch, it's not the easiest thing to do to get it in 1st when going much faster then 5 mph.
http://auto.howstuffworks.com/transmission.htm The problem the OP had was the extreme difference between engine speed and wheel speed when trying to go from second into first gear. The easy solution is to rev match between gears getting the engine to a more comparable speed to the intermediate shaft, or you can also double clutch, thereby bringing down the speed of the intermediate shaft closer to the speed of the motor. The latter would mean a heavier jerk as the motor had to spin up to wheel speed very quickly when you release the clutch a second time, so with decent transmissions in performance driving situations, it's better to rev match when down shifting. There is a certain "touch" required there, so that you know how much to rev match, as too much gas or too little will also upset the suspension, potentially sending you into a spin. In a nutshell, all that is why race car drivers are far more under appreciated than they really deserve by your average driver. |
Correct me if I am wrong, but solely doing rev matching will match the engine speed to the correct ratio of the wheel speed for the next gear. So you get rid of the jerkiness (clutch forcing engine to correct speed for next gear). But, you are still relying on the synchros to match the input and output shaft speeds. |
I've had this happen to all my cars. Completely stopped at a red light, disangage (press) clutch, try to shift into first, no luck. Solution is to depress and press clutch again and it goes in. I didn't think it was an issue and have never forced it into gear.
While that sounds bad cause poor syncros are being worn (gasp), that's exactly what they were designed to do! Everyone's got a soft spot for syncros, but they have been engineered to be used in exactly this way for the life of the vehicle. Kudos to those that double clutch, but you aren't wrecking your transmission by neglecting to do it. It's like saying you're wrecking your brakes by using those. Under normal use, the syncos in your transmission should last 150,000-200,000 kms. At which point they can be easily replaced with either patience or money. More regarding the OP's message: If you can't get it into first gear while standing dead still, I'd have that looked at. Try replacing your transmission fluid first though. I know I had a bit of trouble when the transmission was cold. If you're rolling, you just need to do a hella good job of rev matching like others have said. And I'm glad others have corrected the hilarity of first gear not having a syncro. |
Rev-match no double-clutch: 1. Disengage clutch 2. Shift to lower gear 3. Raise RPMs (blip) to match lower gear 4. Engage clutch Rev-match w/ double-clutch 1. Disengage clutch 2. Shift to neutral 3. Engage clutch 4. Raise RPMs (blip) to match lower gear 5. Disengage clutch 6. Shift to lower gear 7. Engage clutch Rev-matching only will help save the life of your clutch and provide a smoother downshift. Rev-matching while double-clutching will do everything rev-matching will while also taking the load off your synchros. Just double-clutching with no rev-matching does nothing. And I do know that I don't need to double-clutch. And I don't need to rev match. And I don't need to drive a manual transmission. I do all of it for my enjoyment. Executing a few near perfect rev-match downshifts while double clutching and braking (heel-toe?) is a fun feeling. |
My problem happens when I'm at a dead stop and not rolling. It is good to know I'm not the only one that noticed this happening in their cars.
I have the same issue. Currently in the process of replacing the clutch and flywheel. Will post again when I have results. I sent you a personal message mrha.
| All times are GMT -4. The time now is 07:29 AM. |
User Alert System provided by
