-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   High idling on new FR-S (https://www.ft86club.com/forums/showthread.php?t=42275)
SigmaHyperion 07-22-2013 11:48 AM
Originally Posted by ndsleep612 (Post 1087518)
On a warmed engine, the idle still sits at around 1500rpms for over 30 seconds.
Like I said in my earlier post, every vehicle I've owned for at least the past decade has always done this.
I could have driven it all day long, it could be 110* outside, the engine could be boiling hot, and it'll idle at above 1000 RPM at start-up for at least a little bit before dropping. Unless it's doing it in the middle of a warmed-up drive cycle (i.e. you're stopped at a red light after 15 minutes and it's still high), you're fine.
If I were totally guessing, I would guess it has something to do with an ECU check and the emissions systems in modern vehicles. They certainly seem far more likely to exhibit this behavior than cars in the past, which would drop idle almost immediately.
King Tut 07-22-2013 02:34 PM
Originally Posted by whtchocla7e (Post 1087664)
NORMAL.
This.
BRZnut 07-22-2013 08:06 PM
What is the idle after 10 min of driving?
arghx7 07-27-2013 08:58 AM
it's normal
andrew20195 07-27-2013 09:54 AM
Besides warming up the engine, another purpose of a fast idle is to warm up the catalytic converter. Furthermore, if you tend to drive aggressively before the engine is fully warmed up, the ECM will attempt to warm the engine more quickly than normal.
@OP: I suggest you start the car from overnight cold and time how long it takes for the idle to drop to normal levels -- around 700 RPM.
Khazzy 07-27-2013 10:06 AM
This looked perfectly normal to me. Now when you stop at a light. What happens? Does it sit there?
