-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   5th gear synchro harshness? (https://www.ft86club.com/forums/showthread.php?t=25784)
vwong 01-09-2013 05:47 PM
Originally Posted by OrbitalEllipses (Post 654619)
I find 5-6 to be much worse than 4-5.
I am having the same problem...it doesn't want to seem to go into 6th
OrbitalEllipses 01-09-2013 06:03 PM
Sounds like warranty work. I get into 6th...it's just notchy and grinds on occasion.
vwong 01-10-2013 05:22 PM
oh no it'll go fine but like yours its notchy at times, i haven't had it grind yet though but I'll see what they say when I take it in for my first service. 2-3 has been kinda weird too but it goes away after I've driven it for a lil bit.
gmookher 01-11-2013 09:04 PM
how many of you have "post delivery adjusted clutches?"
Subie 01-11-2013 09:28 PM
Not me.
tech4pdx 01-12-2013 12:47 AM
Never touched mine.
gmookher 01-12-2013 12:56 AM
You have an issue then
Dealer time!
tech4pdx 01-12-2013 12:58 AM
Mine comes and goes based on temp usually. I'll try the pento first and see if less affected by temp.
Gixxer86 01-29-2013 06:38 PM
Same Issue here. Even with the car warmed up, if im getting on the freeway or driving "briskly" on surface streets, then it is pretty harsh(even grinding sometimes) going 4th-5th. Also have the same issue when going from 6th-5th. If i'm doing it to slow down, then its not "quite" as bad, but if i shift 6th-5th to accelerate suddenly, then it is just has bad as the 4th-5th... I rev-match well, car is warmed and only 3K on the car. 5th has always been a little rough since i purchased the car, but it is certainly getting much worse.
tech4pdx 01-29-2013 11:36 PM
This MT is a box of cracker jacks.. (: haha
OrbitalEllipses 02-04-2013 12:49 AM
Drove the car twice today: once to the superbowl party and once back to my house. On both trips I got a grind into 5th gear; once each trip.
ahaghshenas 03-23-2013 04:58 PM
My gears are pretty much good all around but just quicker downshifts from 6th to 5th at mid to high rpm are giving me a small crunch with clutch fully depressed!!
Is this normal?? my car has always done it :mad0259:
andrew20195 03-24-2013 12:55 PM
Originally Posted by Subie (Post 648664)
My thoughts exactly (emphasis mine). I'm wondering if it would be better to downshift into 4th instead for synchro longevity since it comparatively engages with ease. I may change the transmission fluid soon to see if it changes the behavior at all.
Downshifting from 6th to 4th will decrease synchro longevity on 4th gear, as the shaft speed difference will be greater than if you were shifting 6th-5th-4th.
How much will it decrease longevity? I have no clue. :)
EL_to_TBD 03-25-2013 08:09 PM
Has anyone that posted in this thread or the others related to this issue tried the Pentosin fluid?
Did it eliminate the issue?
Thanks.
