It's happened twice so far for me but only in the morning when it is freezing outside.
This has happened to me a few times... I just give it a few seconds and try it again. There was one instance where I was at one of my track event's paddock area, and the car would not start even after a few tries... Some folks started to look over at me and my FR-S because of my difficulty, but then it finally started.
I don't know what to say, but it hasn't been a major issue which has completely failed on me... I have just under 9k miles on my car as of now. |
This seems like another problem in the works ahg
It happend to me once, it just keep turning over/cranking. After 10seconds it started. Few miles later and CEL came on :D Not happend since i got CEL fixed though.
Sent from my flux capacitor using Taptalk |
happened to me today, parked it outside beginning of my shift, 8hrs later, trying to go home the car wouldnt start properly until a 2nd time. Ill try to record it with my phone next time.
First time this has happened at 5770kms |
This happened to me tonight with approximately 1,800 miles on the car.
Turned the key cranked strong for 3-4 seconds but did not turn over, I was about to give up and try again and it turned over strong which was weird. |
first time driving cars for some folks here it seems...
I think its pretty normal. I usually pause for a second when turning the key before cranking to let fuel pressure come up and things settle.
Also, everything needs to sync and its a little more tricky on a high compression engine. Motorcycles don't always start on first try either. I would rather have it take its time or a few tries than start incorrectly. :burnrubber: |
I've had the same problem in my AT. Not sure what it is though, also not overly worried as I see its a common problem that hasn't led to much else.
I'm having the issue too. It has happened every day this week. It just started this week too.
And yes, I always wait for the pump to prime... |
This has happened to me 3 times so far but only on very cold mornings. If it's not happening in cold weather, I'm thinking it might be a problem. Maybe a new battery will fix the issue.
I always turn the key on for about 5 seconds before starting the car and I have never had that issue
| All times are GMT -4. The time now is 06:23 AM. |
User Alert System provided by
