http://www.ebay.com/itm/Brand-New-3-...AAAOSw5VFWNp22 I also find the specific model in Chinese market. But shipping is gonna cost a fortune. |
After not being able to find the complete screen, I decided to go another route.
On mine, the display still works. Only the touch screen failed. They are two separate components attached with some adhesive. Most all resistive touch screens are the same except for size so I worked it off with a razor and cleaned the surface with alcohol. A quick search on ebay found a 3.5" touch screen measuring 77x64mm which is very close enough. Once it's on, the calibration process will fit it. http://www.ebay.com/itm/152070987652 EDIT: This looks like a direct replacement to the touch screen. I ordered both but Digi-Key will get here sooner. https://www.digikey.com/product-deta....5Z-ND/2626417 In reality, you can use a larger screen as well since calibration will take care of matching pixels to values. You need to make sure the plug is a 1mm pitch. A lot of them are 0.5mm pitch but there are adaptors and extensions out there as well. The screen wont be here for a week or so. Will update more then. https://goo.gl/photos/mJqGznKX7QpLkPh38 |
Fixed!
5 Attachment(s)
The screen at
https://www.digikey.com/product-deta....5Z-ND/2626417 Worked perfectly for $15.00 with shipping. The adhesive is already around the edge so you just pull off the clear plastic and stick it down. The plug is in the right place but a little longer but doesnt affect anything. A drop of glue on the old posts and it's done. I added a strip of foam around the outside. |
Just did this. I haven't been e85 in months! Took me two hours to flash back to 91 with a broken touch screen a while back.
You rock OP :bow: |
Could someone who has done this shed some light on how the two outer case parts snap together? Maybe some close-up pics? Can the case be opened without breaking the tabs if you know where/how to pry?
Thanks! |
no its a sealed unit ,not meant to be opened, you have to cut through those tabbs |
ISO a display screen. Can someone guide me where to find one? Thanks
Does anyone know if this would be a direct replacement? The model number is off by one character.
https://www.mouser.com/productdetail...iYaSfBKA%3D%3D |
I've been asked a few times through PM's for the links to the replacement parts. It's easy to fix these, but you will beat up the case of your OFT quite a bit. Therre's no graceful way to crack open that clam case!
A very nice guy on FB gave me these links in October. I won't call him out, in case he wants to stay lurking, but if you are reading this, you're the best dude! So heres The LCD https://www.mouser.com/Search/m_Prod...68-UMSH8252MDT You'll need The touch display as Well https://www.digikey.com/product-deta...-5Z-ND/2626417 |
Looks like those links are broken. I think these are the correct ones:
UMSH-8252MD-T https://www.mouser.com/productdetail...iYaSfBKA%3D%3D TS-TFT3.5Z https://www.digikey.com/product-deta....5Z-ND/2626417 |
| All times are GMT -4. The time now is 04:44 AM. |
User Alert System provided by
