follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 2
1
2
Showing results 1 to 30 of 49
Search took
0.72
seconds.
Search:
Posts Made By:
rns294
Forum:
Suspension | Chassis | Brakes --
Sponsored by 949 Racing
12-30-2020, 03:36 PM
7
Rear Sway Bar Bracket Bolt Size
3,035
Posted By
NoHaveMSG
I believe they are 8X1.25, probably about 25mm...
I believe they are 8X1.25, probably about 25mm long.
Forum:
Forced Induction
10-17-2019, 05:26 PM
6,011
Jackson Racing Supercharger Owners Thread
2,077,385
Posted By
peaches
yes, ribbed on both side for double the pleasure
Forum:
Forced Induction
06-20-2019, 10:05 PM
6,011
2,077,385
Posted By
Brz866
I've always used the k&n filter cleaner and oil...
I've always used the k&n filter cleaner and oil kit. Just follow the directions from the kit and it gets the filter like new. The pre filter sock isn't necessary due to the filter being protected and...
Forum:
Forced Induction
05-21-2019, 04:35 AM
104
I CANT MAKE A DECISION!!! Jrsc or edelbrock.
29,770
Posted By
evoto86
Turbo
Turbo
Forum:
Mid-Atlantic
02-04-2019, 02:19 PM
20
Valve Spring Recall Dealers
4,677
Posted By
kmbkk
I got my letter a couple of weeks ago and dropped...
I got my letter a couple of weeks ago and dropped by Priority and Lustine dealers to discuss my options. Priority is willing to do the recall on my car as-is, and not charge additional hours for...
Forum:
Forced Induction
01-11-2019, 05:20 PM
6,011
2,077,385
Posted By
S. Snake
Of the various cars I have owned this car has...
Of the various cars I have owned this car has been the most receptive and easy platform to fix literally bolted on my JRSC tuned it using the CARB tune and have been rolling happy for 14k miles no...
Forum:
Forced Induction
01-11-2019, 04:05 PM
6,011
2,077,385
Posted By
mrg666
Oh, come on! These are so generic words, almost...
Oh, come on! These are so generic words, almost meaningless. How about 20K miles without any problem when it is done/maintained right? That is me.
I can blow up a stock NA engine for you. Just...
Forum:
Engine, Exhaust, Transmission
11-06-2018, 02:45 PM
23
So, I found a weakness in the FR-S
3,972
Posted By
Roadcone
155k miles isnt what i would consider little use...
155k miles isnt what i would consider little use lol.
Forum:
11-06-2018, 02:38 PM
23
3,972
Posted By
Sapphireho
Is this post for real?
Forum:
Forced Induction
10-30-2018, 03:49 AM
90
Would I boost this car again if I had the chance?
18,465
Posted By
Verl0r4n
If all you wanted was a rwd coupe with 300whp...
If all you wanted was a rwd coupe with 300whp then you should have just bought an M2. Half the joy this car has is the modification not the end result. Theres a 1001 different things you can do with...
Forum:
06-08-2018, 02:36 PM
53
OS Giken Super Lock LSD Install
19,117
Posted By
CSG Mike
an OEM Torsen LSD becomes open when one wheel...
an OEM Torsen LSD becomes open when one wheel loses traction or is lifted off of the ground.
The OS Giken, or similar clutch type LSD, can physically lock the rear wheels together, so that you...
Forum:
06-08-2018, 01:44 PM
53
19,117
Posted By
justinco
If you were ever wondering what it takes to install a OS Giken differential, here you go :) This isn't so much a howto but a general guide to be used as a reference. Not a terribly difficult job but...
Forum:
Forced Induction
05-13-2018, 02:05 AM
6,011
2,077,385
Posted By
CSG Mike
Dirty belt/pulley.
Dirty belt/pulley.
Forum:
Forced Induction
05-12-2018, 04:21 PM
6,011
2,077,385
Posted By
idkwhatimdoing
For me, I believe it was due to a worn belt....
For me, I believe it was due to a worn belt. Sprayed it with a can and a half of belt conditioner and marine-duty dry silicon lube and it went away. The issue with that is the fact I had to have my...
Forum:
Wheels and Tires
02-23-2018, 10:57 AM
474
WEDS TC-105N 17x9 Dark Gunmetal EXCLUSIVE color - ARRIVED,ready 2 ship,15.7 lbs LIGHT
126,978
Posted By
chimera118
any chance of a side by side shot of the DGM and...
any chance of a side by side shot of the DGM and Hyper Silver?
Forum:
Forced Induction
12-09-2017, 10:08 AM
6,011
2,077,385
Posted By
axelthrasher
Ugh... the things you do for the good of...
Ugh... the things you do for the good of community:
https://i.imgur.com/MIGg2x3.jpg
https://i.imgur.com/tjTKoDD.jpg
Use the pulleys to figure out which direction the BPV is oriented.
To...
Forum:
12-01-2017, 12:56 AM
7
Info on OS Giken STR1C, STR2C and TR2C Clutches
3,888
Posted By
CSG Mike
1. All of the clutches above have the TOB/Fork,...
1. All of the clutches above have the TOB/Fork, regardless of retailer. I'd hope you support someone who can actually answer your questions and provide technical support though!
2. No
3. No
Forum:
11-30-2017, 03:40 PM
7
3,888
Posted By
CSG Mike
I can help. HTR1C: TY421-AR6 Hard Cover -...
I can help.
HTR1C: TY421-AR6
Hard Cover - Single Plate – Solid Hub – Includes Reinforced Fork Kit Conversion (OS Clutch Exclusive) and Release Sleeve Assembly (Fork Kit Exclusive).
MSRP:...
Forum:
Forced Induction
11-13-2017, 01:59 PM
6,011
2,077,385
Posted By
Jackson Racing
The included bypass valve is an OEM level valve...
The included bypass valve is an OEM level valve used in a lot of OEM applications. We have used it reliably in all our personal street and race vehicles. Our STU race car used an off the self valve,...
Forum:
Forced Induction
11-13-2017, 01:26 PM
6,011
2,077,385
Posted By
Jackson Racing
The lower reservoir location applies to C8 and...
The lower reservoir location applies to C8 and C15 unit seals. C30 and C38 units have a different seal setup. Example: Our prototype K-Track setup on the Super Lap Battle Unlimited FWD record killing...
Forum:
Forced Induction
11-12-2017, 08:02 AM
6,011
2,077,385
Posted By
Deep Six
New oem block/crank/girdle/oil pump & cover...
New oem block/crank/girdle/oil pump & cover assembly
Wiseco forged 11.5:1 pistons
Manley I Beam forged rods
ARP studs
GSC +1 Valve Train including Beehive Spring kit
Original heads with P&P...
Forum:
Forced Induction
11-09-2017, 06:56 PM
6,011
2,077,385
Posted By
Deep Six
Ordered today !! James will calibrate the tune...
Ordered today !! James will calibrate the tune and drop the rev limiter for me. Track weekend scheduled for Dec 2/3 very interested to see if the extra midrange punch allows me to consolidate...
Forum:
Forced Induction
11-08-2017, 12:16 PM
6,011
2,077,385
Posted By
CSG Mike
Their kits are made to order. Lead time isn't...
Their kits are made to order. Lead time isn't affected by where you purchase, but the level of support you receive is affected.
Forum:
Engine Swaps
10-24-2017, 01:44 PM
29
Pure Auto's Swap Compilation Thread - 2JZ and LSX !
15,574
Posted By
Pure Automotive
Follow This Thread, As Well As Our Swap Blog On Facebook.com/SwapYour86
First of all, I'd like to thank Photobucket for completely ruining all my other threads by asking me for $400 a year to...
Forum:
Forced Induction
10-17-2017, 11:43 PM
6,011
2,077,385
Posted By
Jmonty
Looking like in the next few months I could tell...
Looking like in the next few months I could tell you
Forum:
Mid-Atlantic
10-01-2017, 02:45 PM
11
Anyone of JRSC or Edelbrock?
3,283
Posted By
SpectreRT
Yup, Sheets station. And there is a new station...
Yup, Sheets station. And there is a new station in Chantilly IIRC.
Forum:
Mid-Atlantic
10-01-2017, 02:22 PM
11
3,283
Posted By
VoltsFRS2013
Subjectively speaking, I've found that most...
Subjectively speaking, I've found that most Sheetz gas stations sell E85, so if you can find some locally to where you are check in there.
Forum:
Mid-Atlantic
09-05-2017, 09:37 PM
7,404
Mid-Atlantic spotting thread
1,197,733
Posted By
JakeRogue
4221 John Marr Dr Annandale, VA 22003 United...
4221 John Marr Dr
Annandale, VA 22003
United States
I'll be there this Thursday. My FRS plates say "TRUENO"
Forum:
Mid-Atlantic
09-05-2017, 09:34 PM
7,404
1,197,733
Posted By
ChristineAlexa
Where's "The Block"? I'm in Manassas, and new to...
Where's "The Block"? I'm in Manassas, and new to the board (just got my car last week). Planning to do a R&P swap in the next month or two max on a stock 2013 FR-S auto
Christine
Forum:
Engine Swaps
08-27-2017, 06:19 PM
21
V8 swap timelapse video
6,347
Posted By
mkivsoopra
Overall, took a little over 10 hours, after the FA20 was removed!
http://www.youtube.com/watch?v=Oe4w7e8Wo9s
Page 1 of 2
1
2
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
08:41 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
