#15 |
Master Collaborator
Guys, (and gals?) I just did a lengthy and informative write up that addresses what sounds to be the situations you are having.
It can be found here: https://www.ft86club.com/forums/showthread.php?t=141915 |
#16 |
Drives: 2017 Brz
Door speakers not working after new head unit install
Thanks so much for your write up. I had the same issue with the front door speakers not working. The rear amp is not getting any power. With your write up and a few others I was able to identify the brown wire coming from the car that had no mate in the Crutchfield supplied Crux adapter. I cut the brown wire from Pin 9 and connected it to the REM out wire from the new head unit, along with the antenna amp wire. Now the speakers work and I have radio reception.
#17 | |
Master Collaborator
Not sure if your comment was aimed at me or not, but if it was thanks. I just spent a few minutes editing that write up so you don't have to scroll all the way down to see the diagrams that I mentioned when describing the different harnesses, plugs and adapters. Just makes it easier (less difficult?) to read. |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | bcj (04-27-2021) |
#18 |
Drives: 2017 Brz
Absolutely! Both you and the OP. Putting your posts together in my mind got me on the right track and now I have sound!
Now to deaden the other sounds. (Without adding much weight. This thing is too fun to ruin it with extra mass.). I have a 2017 that I bought three weeks ago. Sent from my iPad using Tapatalk |
| The Following User Says Thank You to Drafter For This Useful Post: | FR-S2GT86 (04-27-2021) |
| door speakers not working | number1Tango | Electronics | Audio | NAV | Infotainment | 23 | 04-03-2022 07:03 PM |
| MD: BRZ Head Unit + Speakers | itsfun | Audio/Visual, Electronics, Infotainment, NAV | 2 | 04-06-2013 09:03 PM |
| FS: Stock BRZ head unit (Sat, Nav, BT audio, etc) with amp & speakers | Mach V Dan | Audio/Visual, Electronics, Infotainment, NAV | 20 | 02-18-2013 04:59 PM |
| New head unit/speakers | Dkittrell | Electronics | Audio | NAV | Infotainment | 5 | 06-27-2012 03:01 PM |
