Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-15-2015, 07:41 PM | #1 |
Drives: 2015 BRZ
Berk Dual Tip Muffler Delete Drone
I just installed a Berk dual tip muffler delete on my BRZ. This is the first time I have ever messed with the exhaust on a car. I am happy with the deep sound it makes, however at around 2.3k and 4k rpm, it drones really badly.
Is there any way to fix this? I love the sound except for that drone! I bought it about a week ago and I can't get over it. I am thinking I will have to return it if I can't fix the drone. Is there a way to get rid of the drone? If not, is it possible to return the muffler delete to Berk if it has been less that 30 days? Thanks. |
12-15-2015, 08:21 PM | #2 |
Drives: frs
You still have stock resonator?
12-15-2015, 08:53 PM | #3 |
Drives: 2015 BRZ
Yes, I kept everything that I took off of the car. Sorry if this is a stupid question (I am a completely new to exhausts) but is the muffler and resonator the same thing? If not, where is the resonator?
12-15-2015, 09:08 PM | #4 |
Drives: Scion FR-S
If all you did was replace the axle back, which is what the Berk is, then there should be very little drone. I have a Mach V dual exit delete, 2.5" overpipe and catless front pipe and I love the sound. Is it loud? Hell yes when I get on it. But I have learned where to keep the RPM's to keep it calm. Right around 3k RPM seems to be the sweet spot for me.
Also, if you JUST put it on, give it some time to get coated with some exhaust soot. That will tone it down a little too. |
12-15-2015, 09:25 PM | #5 |
Drives: 2015 BRZ
12-15-2015, 09:33 PM | #6 |
Drives: Scion FR-S
Well it was pretty quick for me as I am down 1 cat. Give it a couple weeks. The tips will turn black inside then you'll know. It'll get more and more coated as time goes by.
If that still doesn't fit for you, I'd a get a front pipe with a helmholtz resonator. Nameless Performance makes one. I would advised if you do this, take your car to a GOOD muffler shop and have them make a 2.5" mid pip with a silencer. I say this because I originally put my muffler delete on first and it added a kick in the pants. When I put on the overpipe and front pipe, I feel like I lost some power. After watching a very informative video on exhaust design, I think it added a vacuum pulse that wasn't there before and jacked it all up. |
12-15-2015, 09:41 PM | #7 | |
Not a troll
12-15-2015, 10:19 PM | #8 | |
Not A Member
Drives: 2014 Mustang GT
a little
12-15-2015, 10:28 PM | #9 |
I'm going to add a tally to the "don't hold whatever rpm you hear your drone at" clan. I also recently installed the Berk muffler delete, single exit flavor, and have noticed drone in certain spots.
It even drives one of my buddies so crazy he hates riding with me 😂 so I usually just change my speed for the gear I'm in, or down shift, or turn up the radio. Sent from my 831C using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
The Following User Says Thank You to 15limited For This Useful Post: | rosol16 (12-15-2015) |
12-15-2015, 11:03 PM | #10 |
Drives: '15 red FR-S SSC
I too have a Berk single exhaust muffler delete. I love it and have no complaints. I must admit that i don't even know what drone is so either i don't have it or i like it. Please advise.
12-15-2015, 11:08 PM | #11 | |||
I'm almost 100% sure it's sensory adaptation and you getting used to it, there is no muffler or muffler walls to speak of to get coated in carbon for any sort of sound difference to take place, it's literally just a pipe. If he really wants some less drone , he should take it to a shop and ask them to weld in a resonator in the pipe that runs between the two tips. I also agree with getting the nameless front pipe with helmholtz resonator, and you might as well get the nameless mid pipe as well because then you'll essentially have a full header-back done, because the nameless front pipe replaces the overpipe as well
12-16-2015, 02:07 AM | #12 | |
humfrz |
The Following 4 Users Say Thank You to humfrz For This Useful Post: |
12-16-2015, 02:14 AM | #13 | |
http://www.ft86club.com/forums/showthread.php?p=923261 humfrz |
12-16-2015, 02:18 AM | #14 | |
humfrz |
The Following 3 Users Say Thank You to humfrz For This Useful Post: |
Tags |
berk, brz, drone, muffler delete |
Similar Threads | ||||
Custom Muffler Delete vs Berk Dual Tip Muffler Delete | eric2523 | Engine, Exhaust, Transmission | 7 | 07-27-2015 09:40 AM |
wtb berk dual muffler delete, berk catless front pipe | interna | Want-To-Buy Requests | 1 | 12-15-2014 04:52 AM |
WTB: Berk Dual Muffler Delete, Berk Catless Test Pipe. | interna | Engine, Exhaust, Bolt-Ons | 0 | 11-26-2014 07:17 PM |
WTB: Berk Dual Muffler Delete, Berk Catless Test Pipe. | interna | Canada Classifieds | 1 | 11-26-2014 03:47 PM |
WTB Berk Dual Exit Muffler Delete or Works AB Delete | Admired | Want-To-Buy Requests | 2 | 09-10-2013 04:20 PM |
