Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
11-02-2015, 11:23 PM | #1 |
Drives: RX-7 / BRZ
Smoke test the twins for evap.
Where are tech plugging into when you smoke the twins for an evap leak? With the main evap lines tucked under the intake and the canister tucked up behind the fuel tank I cannot seem to find any good place to enter from. I also don't seem to see an evap schrader to testing the system.
Just t-off the vaccuum lines on the upper intake under the engine cover and fill the whole system with smoke?
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
Similar Threads | ||||
Evap Emissions Purge Flow CEL | avishenoy1 | Issues | Warranty | Recalls / TSB | 5 | 05-01-2020 06:22 AM |
EVAP LINES..build dates? | nickmerronesucks | Forced Induction | 4 | 08-04-2015 10:22 AM |
DIY clamping the evap vacum ports under the manifold!! | charged86 | DIY (Do-It-Yourself) Guides | 9 | 04-08-2015 06:56 PM |
EVAP Solenoid | Ryan P | Forced Induction | 0 | 06-25-2014 08:43 AM |
The Smoke Leak Test - Why We Use it, and Why it Works | Circuit Motorsports | Engine, Exhaust, Transmission | 0 | 06-04-2014 04:37 PM |
