Drives: Drives like a crab.
[DIY] Fixing the LED turn signal initial delay
Hi everyone,
As you may have read, I've remplaced all the turn signals bulbs with LED and swapped the flasher on my GT86 (http://www.ft86club.com/forums/showt...16#post2429616). Thing is, the new flasher does not hyperblink but it does have a "initial delay" meaning the first blink is much longer that the one following. This can be pretty annoying and I've decided I couldn't live with it because I'm really anal with details on my car. LED drawing much less current than bulbs, I've come up with a really simple mod on the stock flasher of my GT86 (I believe it is the same flasher on the BRZ and FR-S). It is super simple and does exactly what you expect it to do: acting like your regular, stock bulbs used to. All you need is : -A soldering Iron -A solder sucker -A 0.12ohm min. 1W resistor -Some solder Here is the mod step by step : 1. Remove the flasher. See DiodeDynamics really well-explained video. [ame="https://www.youtube.com/watch?v=AAEz3YC8SCA"]FR-S / BRZ Fix Turn LED Hyperblink with Flasher - YouTube[/ame] 2. Take it down. ![]() 3. Remove the stock "metal bar" which is actually a *approx.* 3ohm resistor. ![]() 4. Replace it with a 0.12ohm minimum 1W resistor. My local electronic shop only had 5W which are bigger. I recommend, if you can find some, to go with 1 or 2W so you can put back the grey plastic cover. ![]() 5. Put it back, smile, offer flowers to your wife and take your kids to disneyland. Pro : -Cheap ! Cheaper than replacing the stock flasher or adding resistors to every LED -Safe ! Safer than adding resistors that can get SUPER hot and eventually set fire to you car and burn your entire neighbourhood. -You feel like Einstein. Because DIY. Since LED have a muuuuch longer lifespan than bulbs, you eventually don't need this feature indicating that one of your LED is dead. Just check it by yourself once in a while and it will by alright. If you have any question, feel free to ask! Have a nice day. |
| The Following 6 Users Say Thank You to Wil For This Useful Post: | kch (02-18-2016), Kodename47 (10-31-2015), ragequitfail (12-04-2015), stevesnj (11-21-2015), turbos86 (09-16-2016), Vin (03-29-2017) |
Drives: 10 Series FR-S #207
Or you could just buy a tap a turn and be done in less than 5 minutes
#3 | |
Shut up baby, I know it
Drives: 2013 BRZ DMG
| The Following User Says Thank You to BlackJesus For This Useful Post: | YamahaR86 (11-21-2015) |
JDM Vaping Stance Nation
Drives: 2013 White
Right? I can't justify spending that much money on a relay just so the initial blink is proper. Prefer to save that money and put it towards other mods.
| The Following User Says Thank You to YamahaR86 For This Useful Post: | stevesnj (11-21-2015) |
#5 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
That is a neat mod for people who don't want all the Tap-Turn features. I like Tap-Turn, though
![]() http://www.seriesblueadventures.com/...-relay-upgrade |
#8 | |
Awesome! I been living with the delay and just signaling earlier but this is the most inexpensive solution. No way i'd buy an $80 relay and have the useless features i'd never use. Who would? But great idea. Thanks!
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | YamahaR86 (11-21-2015) |
Drives: 2015 FR-S
Damn wish I found this thread before I put in the one that came with my toms. My relay was a pita to get out. At least the stock one is out so I can work on it.
Can you post a link to the resistor you recommend using? I might buy one at the store or online but I just want to make sure I know what it looks like so I buy the right one. |
#10 |
Drives: UK GT86
It's been a while since I've bought components, I assume that this will do:
http://uk.rs-online.com/web/p/throug...stors/2942798/
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | ragequitfail (12-04-2015) |
#11 |
Drives: frs
Wanted to say this was very helpful. The delay was annoying me as well. One thing I ran into was I put in switchback led turn signal lights. When the turn signals lights are just the amber, the .12ohm was sufficient. But when the white light on the switchback is on, when the turn signal is engaged I get the hyper flash. I bought a bunch of the .12ohm resistors so I connected 2 in series to make up a total of .24ohm and that worked for the switchbacks. Wanted to share that in case anyone else runs into the same problem.
#12 |
Drives: UK GT86
Finally got round to doing this as I'd lost my soldering iron. Thanks again!!
.: Stealth 86 :.
#13 |
Drives: Subaru BRZ
having some trouble sourcing this particular resistor locally. just curious, why 0.12ohm and 1W? if the stock is 3ohm, don't we need more to counter hyperblink? does wattage matter? note that I currently have DD bulbs and flasher installed, but like to fix the initial delay as well.
#14 |
Drives: 2013 BRZ Premium MT
You can measure the power consumption of the LED bulbs you're using and calculate a much more exact resistor value, as well as understand how much power the resistor needs to dissipate:
http://www.ft86club.com/forums/showthread.php?t=114284 |
| Turn signal camera? | wootwoot | Electronics | Audio | NAV | Infotainment | 9 | 05-16-2015 04:47 AM |
| Turn signal lights | whip | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 02-26-2015 11:45 PM |
| How to: Fixing hyper blink on LED turn signals | Laika | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-20-2013 07:58 PM |
| Anyone seen these turn signal/drl less? | djliquidsteele | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-15-2012 04:32 AM |
