Old 09-26-2015, 12:09 AM   #1
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Help with sway bar end links
Helppppp!!!!!
I'm replacing my front struts and i ran into a problem with my sway bar end links!
The bolt that attaches to the strut just keeps spining!
The washer isn't staying completely as well!
Now i can't remove the nut off the strut
Instagram: trevor.parque
Old 09-26-2015, 01:21 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Doesn't the endlinks have the Allen hex in the middle or on the other side?
Old 09-29-2015, 10:51 AM   #3
MisterSheep
Killed Scion
Wow this ended up being a total bitch to do...
I had to clamp down with a wrench to the bolt to pull the nut off. The bolt was totally damaged as well. I ended up just getting a new sway bar end link to install..
I think someone has been messing with it before because the nut was already rounded off as you can already see
see below images..
Old 09-29-2015, 11:02 AM   #4
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
There can also be flat spots a wrench will fit on between the sway bar and the body of the endlink.
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Front Sway bar end links rick s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-09-2015 11:33 PM
WTB: Rear sway end links or sway bar with endlinks JoeBoxer Want-To-Buy Requests 1 08-03-2015 01:20 PM
Need help! coilovers/sway links issue P_say86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-19-2015 08:35 PM
Setting adjustable sway bar links Im_SPEED Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-01-2012 09:12 PM
