Drives: 2015 BRZ
TESTED- Perrin Master Cylinder Brace
We had a spare analog input, a spare shock pot, a Perrin master cylinder brace, and some time to kill. Let's find out if it actually works!
First thing we did was mount a shock pot horizontally in line with the master cylinder: ![]() Interestingly enough, we had marginal deflection. On the order of a few thousandths of an inch. Watching it, we noticed the master cylinder was actually deflecting upwards, not forward like you'd think. It rotates around a point on the firewall, roughly, so that the end is pushed upwards. So we got a little creative with some machining measurement fixtures, and wound up with this: ![]() Despite the angle of the picture, the shock pot was perfectly vertical and in line with the front face of the master cylinder. Once we had that setup, we definitely recorded some deflection. The tests were performed with the engine off (no vacuum assist). The brake pedal was pressed several times at varying pressure. Brake line pressure was monitored via OBD2 at a resolution of 1 bar (14.7 psi), and the master cylinder deflection was measured via analog channel at a resolution of 0.001" (4 inch linear potentiometer at 12 bit resolution). ![]() You can see here, despite what may be a structurally inefficient position, it's absolutely effective, reducing master cylinder deflection by 57%. Could it be better? Maybe, but the returns would be minimal. You guys already know it improves feel, here's why. |
| The Following 50 Users Say Thank You to GSpeed For This Useful Post: | aegisdrgn (08-23-2015), akyp (08-20-2015), Aztec (10-28-2015), Bergen23 (08-20-2015), bhmax (09-28-2015), calmtigers (08-20-2015), Calum (08-19-2015), Captain Snooze (08-20-2015), ck-GT86 (08-20-2015), Createddeleted (08-20-2015), CSG Mike (08-20-2015), DAEMANO (08-20-2015), Danklvr (08-20-2015), Decay107 (08-20-2015), DocWalt (09-19-2015), drewbot (08-23-2015), DustinS (08-20-2015), emutcfut (08-21-2015), Ernest72 (08-07-2020), Fareast auto part (08-23-2015), Freeman (08-19-2015), FrX (08-20-2015), Griever423 (08-26-2015), Hyper4mance2k (08-20-2015), JB86'd (08-21-2015), JD001 (08-08-2020), JonAvalon (08-20-2015), Jonsey (08-19-2015), JS + BRZ (08-27-2015), kch (08-19-2015), MrSkubi (01-23-2018), OkieSnuffBox (08-20-2015), PandaBRZ (08-20-2015), Pekingduck (08-22-2015), PNW FRS (08-27-2015), Pointmutation (06-10-2018), Purist (08-13-2020), PWBRZ (08-25-2015), R2RO (10-30-2015), Racecomp Engineering (08-20-2015), Shankenstein (08-19-2015), solidONE (08-19-2015), T-Steve (08-05-2017), TheVoiceOfReason (08-20-2015), tintumz22 (08-07-2020), waterbison777 (08-21-2015), Wepeel (08-21-2015), WhiteFRS69 (08-20-2015), why? (08-20-2015), wparsons (08-19-2015) |
Drives: TBD
VERY Cool!! Thanks for the Info!
Drives: 2015 FR-S
Practically every thread by you guys provides real data or at least truly useful information.
Thanks for taking such a comprehensive approach to developing the platform, and above all, sharing the results with us on a regular basis. If I had 10 posts to my name I'd just click thanks, but this probably gets my point across better anyway. |
| The Following 3 Users Say Thank You to Rameus For This Useful Post: |
Drives: 2013 Subaru BRZ
This is awesome! Thank you so much for sharing!
Only happy when it rains.
Drives: series.blue
that is total win.
Drives: Scion FR-S 10 Series #2263
The numbers don't lie! Thanks for making the test results available!
Drives: 2015 FRS Hot Lava 2014 CT200H
This is why I love this community. Great information
Open Flash Tablet Stage 1 93 | Borla Cat-Back | VOSSEN VFS1 | Eibach Sportline
Drives: 2010 MS3
Awesome stuff. Thank you so much.
Drives: 2022 GR86
#10 |
#11 |
Drives: 2022 GR86
#12 |
| Perrin Master Cylinder Brace | clintavo | Brakes, Suspension, Chassis | 2 | 05-28-2015 01:58 AM |
| Perrin master cylinder brace | jack43 | Brakes, Suspension, Chassis | 1 | 11-30-2014 12:51 PM |
| Perrin master cylinder brace | SubaSteve | Brakes, Suspension, Chassis | 9 | 01-11-2013 11:46 PM |
| Perrin master cylinder brace for sale | SubaSteve | Mid-Atlantic | 0 | 01-07-2013 08:52 PM |
