| Engine, Exhaust, Transmission, ECU Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
| View Poll Results: What Exhaust set-up should the FT come with? | |||
| Single Exhaust - 1 exit |
83 | 36.89% |
| Single Exhaust - 2 exits (2 mufflers) |
70 | 31.11% |
| Single Exhaust - Centre |
14 | 6.22% |
| Dual Exhaust |
58 | 25.78% |
| Voters: 225. You may not vote on this poll | |||
Drives: Lexus IS 300
Exhaust system: dual or single
Concept pictures suggest that the FT is equipped with dual exhaust. Although this setup is aesthetically pleasing, I think its unnecessary. First off its a 4 cylinder, a single exhaust should be sufficient. Iirc, the 4 cylinder audi a4 and the hyundai gen coupe and some othersn come with it and its nice and all but it adds cost and weight without any significant performance gain. Well I'm sure 20-30 extra lbs below the centre of gravity won't have any noticeable negative affect (it might actually help in lowering the cg) but COST! I'm sure many of us who get this car will be thinking of mods and let's face it, many of us (although I'm sure some of u are) aren't made of money, and if it is a true dual exhaust then its gonna cost nearly twice as much. And I already think those brand name exhaust systems are over priced: its just a length of steel tubes. But that's besides the point.
What are your views on what the FT should come equipped with: duals or singles? Ok I've added a poll. place your votes =D Last edited by KiingDavid; 01-24-2011 at 06:12 AM. Reason: Added a poll |
Kuruma Otaku
Drives: BD Legacy and Mk3 Supra Turbo
It's just split into dual exits at the end like an S2000.
Because titanium. |
Drives: Toyota
I like to see duals on the car because of symmetry.
if thats the case i hope the exhaust piping run on the right alongside the drive shaft to balance out the weight of the driver as much as possible. but knowing its a japanese/european production where its rhd it'll be on the left.
#5 | |
Kuruma Otaku
And don't let no fatties in the passenger seat! Heh.
Because titanium. |
#6 | |
Site Moderator
Drives: '00 Subaru 2.5RS
For me, I like dual looks... but only need one, so I'll vote for single exhaust. |
Drives: RX8 S1
the thing is the size of the muffler is what makes most of the weight, most of the time when there is dual exhausts (one pipe branching to 2 tips), the muffler is only slightly larger than if it was for single exhaust. i prefer dual as i like symmetry
Supra Owner
Drives: 1995 Toyota Supra UK Spec
Single. Less complicated, cheaper, and highly unneccessary on a boxer engine IMO - and a single can look beasty if done correctly (Supra
)IMO dual exhaust should only be used on V (or W)-layout engine's. There is no real reason to use them otherwise.
Drives: RX8 S1
if the exhaust is a single with single muffler with 2 exists its not complicated and only slightly cheaper and heavier (for the extra pipe from muffle to out)
#10 |
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
honestly, i don't really care, as long as it looks good.
my MR2 came with a dual-exit muffler, and now it has a single exhaust on it.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs 1990 240SX Coupe - sold 2008 Civic Si Sedan |
#11 |
Registered user
Drives: 99 impreza coupe
I am hoping for a single, if the car is designed to have a single it wont look as unbalanced when I change it to an aftermarket single.
#12 | ||
hashiryu
Drives: Cattle
![]() A flat engine and a V would share that commonality. Two different banks. So not a very good example. |
#13 |
Drives: RX8 S1
Oh wait brainwave
Single in the centre that way it's "lighter" simpler and symmetrical ![]() Prefferably mounted inside the bumper with a proper diffuser underneath
#14 |
rookie drifter
Drives: 1987 ae86, 1985 celica gts
most of 4 cylinders dual exhaust can use a camaro sport muffler and will cost around 30$ more than the same quality/size muffler with single exit.... not a big matter... but I like a lot middle exits like mini cooper S, the turbo versions have the muffler in the center of the car, verrry cool looking and weight distribution
#15 |
Kuruma Otaku
Center exit exhausts have always looked like the car's asshole to me since the Boxster...
Because titanium. |
#16 | |
Drives: RX8 S1
Ok so I will never look at the centre exhaustust without laughing now didn't think of it like that b4..
#17 | ||
Supra Owner
). However, this is usually different with a V-engine because the headers travel outwards in opposing directions, so are travelling away from each other.In my opinion and from my (little) experience, obviously.
#18 |
2.1L 3SGTE
i don't think center exit is the way to go, if for no other reason than there's going to be a differential in the way of where the muffler/piping would need to be...
#19 |
#20 |
Drives: JZX110 Mk2
so am i the only one who has actually voted? ahhwelll single all the way for me keep it simple is pretty much how i like it, plus i really dont care what it comes with as long as it has one, and isnt a full electric car
#21 |
2 wheel member
Drives: 05 Tacoma 4x4 DC MKIV Supra 6spd TT
My vote is a for a single exit but then the rear diffuser is going to have a big ass...hole
Also, I'm almost certain the rear diffuser is not going to be CF but rather plastic. With the tips that close, it's either going to warp it or leave exhaust dust around it.
#22 |
Drives: '12 WRX
| ft 86 exhaust | dalli | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 09-08-2010 09:16 PM |
| Brake override system in the FT-86? | mrKiKaZ | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 02-22-2010 11:33 AM |
