Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-09-2015, 03:38 PM | #1 |
NA Injector Upgrade?
Hey guys, so I decided on building my motor decently and keep it NA for a while until the warranty dies on me. I do have some questions and ideas, though.
My goal before doing any forced induction would be pulleys, bigger throttle body, maybe a bigger intake manifold, header, radiator, oil cooler, and full exhaust. Obviously if custom tuned, would 400-550cc injectors be too much? I want to maximize efficiency of the motor, but was wondering if injectors would help me with more power if I wanna go beyond the standard 210 of NA. I rarely work with injectors, but I figured it's worth asking. Any help or details would be great. |
07-09-2015, 03:44 PM | #2 |
Drives: 2013 Ultramarine FR-S
You shouldn't need to upgrade injectors for N/A power at all. Even when running E85.
07-09-2015, 03:48 PM | #3 |
Junior
Drives: a car
Not really, the stock injectors are fine upto about where avo's turbo kit can get you on low-ish psi. ~260whp. So far i havent seen anyone crack 215 to the wheels NA yet. Hopefully that ultimate NA thread will shine through
07-09-2015, 03:55 PM | #4 |
Stock injectors are good past that on pump gas. 300whp+?
07-09-2015, 04:09 PM | #5 |
So it's not worth at all? Would there be any upsides to going with a bigger size or even a basic fuel pump upgrade?
07-09-2015, 04:24 PM | #6 |
You get to spend money...?
I don't think there is. Not until you go FI. Replacing the pump isn't the easiest thing in the world.
07-09-2015, 04:44 PM | #7 |
Well I'm not looking to /burn/ money, but looking to squeeze out any additional power if I can. If it doesn't help at all then it's really not worth it. I do appreciate the help, though thank you.
07-09-2015, 05:48 PM | #8 |
Drives: UK GT86
The car's not down on power due to not being able rich enough. Plus don't forget you have both sets of injectors. You could run almost 100% of the time DI on a NA car without issue. The DI gives you a lot of fueling headroom.
.: Stealth 86 :.
07-09-2015, 06:25 PM | #9 |
There's zero reason to upgrade injectors on a NA car, unless you're doing a V8 swap, or something...
The Following User Says Thank You to CSG Mike For This Useful Post: | Sportsguy83 (07-09-2015) |
07-09-2015, 10:28 PM | #10 |
Drives: 2014 SWP BRZ, MT
Injectors are one of those things that allow for more power headroom but provide zero additional power by themselves. Think stuff like axles, forged pistons, rods, valve springs (not counting changed CR and stuff like that.)
The answer is racecar. Always.
07-09-2015, 10:52 PM | #11 |
Out of all the stuff you named, only header, oil cooler, and full exhaust is actually needed to make more power. The rest is pretty useless or is not even out yet.
07-09-2015, 10:57 PM | #12 | |
Drives: Neptune GR86
You don't get more power by dumping more fuel in than required.
07-10-2015, 03:02 AM | #13 | |
Drives: GT86-ACE-JRZ-RPF1-Essex
Like swarb said, header is what you need.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
07-10-2015, 03:14 AM | #14 |
Drives: 2013 MT Asphalt FRS
Similar Threads | ||||
after market fuel injector upgrade | BRZ888 | Forced Induction | 4 | 02-24-2015 06:38 PM |
wtb injector aem wideband | kcam86 | Want-To-Buy Requests | 0 | 04-13-2014 08:46 PM |
