Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
06-21-2015, 12:13 PM | #1 |
Drives: 2014 Subaru BRZ (Limited, Black)
Aftermarket Push Clips?
http://www.fastwrx.com/products/push-fasteners
So you know how these terrible things are all over the outside of our cars, most notably the fender liners? Does anyone know if there are any dress-up kits that have these? Or just a better, more durable version? I would pay a pretty penny for some black or red anodized version of this. |
The Following User Says Thank You to BRZBYE For This Useful Post: | HATED1 (06-21-2015) |
06-21-2015, 01:03 PM | #2 |
Time Traveller
I got a bunch of these things off Amazon for dirt cheap in all 3 sizes for our cars. They seem made well enough.
My question about your question is, you can anodize plastic? You could buy then paint them. If you really want a shiny metal look you can paint yours with Dupli-color Metalcast, but I don't know how long that would hold up before it started to chip. http://www.bing.com/images/search?q=...st&FORM=HDRSC2 |
The Following User Says Thank You to DAEMANO For This Useful Post: | HATED1 (06-21-2015) |
06-21-2015, 02:42 PM | #3 |
A Demon
Drives: Raven GT86
I've been thinking about buying a speed nut and trying to use engine dress up bolts but haven't had the time.
Sub'd incase anyone has a better solution. Sent from my iPhone using Tapatalk |
06-21-2015, 03:42 PM | #4 |
Drives: 86
Keeping an eye on this thread too! Need some replacement ones as well.
86 SESSIONS on Facebook! |
06-22-2015, 12:13 AM | #5 |
Drives: Scion FR-S (Hot Lava)
Do you have a link for these?? Words cannot express my frustration with these clips over the years. Nothing on my car has a full compliment of these clips anymore as they are constantly flying off or breaking when I try to remove them with a flat head screwdriver.
06-22-2015, 12:23 AM | #6 | |
link please! |
The Following User Says Thank You to mush For This Useful Post: | DAEMANO (06-22-2015) |
06-22-2015, 12:52 AM | #7 |
Time Traveller
@D18 & @mush
Certainly, [ame="http://www.amazon.com/gp/product/B00588T81Q?psc=1&redirect=true&ref_=oh_aui_detailp age_o01_s00"]Amazon.com: 15 Subaru Bumper Engine Cover Fender And Grille Clips: Automotive[/ame] [ame="http://www.amazon.com/gp/product/B005IC2SNW?psc=1&redirect=true&ref_=oh_aui_detailp age_o01_s00"]Amazon.com: 15 Subaru Front Bumper & Quarter Panel Push-Type Clips: Automotive[/ame] [ame="http://www.amazon.com/gp/product/B00AZOJB2O?psc=1&redirect=true&ref_=oh_aui_detailp age_o01_s00"]Amazon.com: 15 Subaru Engine Cover and Fender Liner Clips 90913-0067: Automotive[/ame] |
06-22-2015, 01:01 AM | #8 |
thanks!
08-16-2015, 12:52 AM | #9 |
I was hoping for a solution that maybe wasn't plastic, or was much much more durable. the "phillips" head clips are atrocious!
04-19-2016, 03:43 PM | #10 |
To anyone who is currently looking for some clips that are better than the originals, I ordered a ton of different, non-Subaru, clips from Amazon. Everything I ordered was stronger, however some fit, some don't. Below I am posting links to the three different products.
1. This is my top choice to replace the 8mm diameter clips in the fender liner. It's not as pretty looking as the OEM ones (before you destroy them after one use). These are also vastly more durable than OEM clips, they don't get ruined when you take them out, and they're easier to take out than the OEM "phillips" style ones. These pop out by inserting a flat head into the side and twist the screwdriver. So no need to turn your wheel to remove clips. They are a very firm fit (My calipers indicate OEM clips are about 7.75mm diameter. These are 7.85mm.) but it does fit and holds everything together way tighter. This is what should have came factory. These fit 8mm holes and seem to be about 1-2mm longer than OEM clips and like the one below, it didn't fit in the fender liner to side-marker bracket. This can be quickly worked around by filing or sanding down the pointed tip. If you want a better clip than OEM but don't care that they look different, this is for you. [ame="http://www.amazon.com/Partsam-100pcs-Plastic-Fastener-01553-0932/dp/B00MWULLP4?ie=UTF8&psc=1&redirect=true&ref_=oh_aui _detailpage_o01_s00"]LINK[/ame] 2. This is a close replacement to the OEM, however these fit a bit tighter and are vastly more durable. However, they are about 1mm longer than OEM, so these do not fit in the place of the clip that attaches the finder liner to the front side-marker bracket.... the hole in the fender liner behind the side-marker light. They work for all other locations that need 8mm diameter clips. These fit the 8mm holes. My issue with these is that they clip together so well, they're more difficult to unlock than the OEM clips. So if you want OEM look, better fit, more durable, but harder to get unlocked, this is for you. [ame="http://www.amazon.com/Subaru-Engine-Cover-Fender-90913-0067/dp/B00AZOJB2O?ie=UTF8&psc=1&redirect=true&ref_=oh_aui _detailpage_o00_s00"]LINK[/ame] 3. This is the odd-ball of my choices. This is the replacement for the larger clips under the bumper that hold the various trays and mud-guards together. These are very similar to OEM, however the material seems a bit stronger and the fit is tighter (no problems though). These fit the 10mm hole. These are really similar to the clips in the top of the bumper (in the engine bay) that hold down the metal bracket and rubber seal between the hood and bumper. [ame="http://www.amazon.com/PartsSquare-Fender-Fastener-Retainer-Subaru/dp/B012Z2X2LE?ie=UTF8&psc=1&redirect=true&ref_=oh_aui _detailpage_o04_s00"]LINK[/ame] 4. Here is the original 8mm Subaru clip. Part Number 46064AE000. LINK Last edited by BRZBYE; 04-19-2016 at 03:43 PM. Reason: formatting |
The Following 9 Users Say Thank You to BRZBYE For This Useful Post: | 8R6 (04-19-2016), frosty288 (01-19-2017), gkubed (09-03-2019), HamburgerSushi (07-12-2017), jcw99 (04-19-2016), Nails (07-12-2017), Spacemane969 (07-29-2019), SPCorBUST (05-23-2018), ysu (07-01-2016) |
07-12-2017, 06:23 AM | #11 | |
Drives: 2017 Subaru BRZ 6MT, Perf Pack
07-12-2017, 11:58 AM | #12 |
Drives: 2019 Mazda Miata RF
Change everything to camloc's?
https://www.pegasusautoracing.com/gr...upID=HARDCAM27 or Dzus? https://www.southco.com/en-au/produc....html?hid=7345 |
Similar Threads | ||||
Exhaust Clips | VSJT_10 | Engine, Exhaust, Transmission | 3 | 11-29-2014 05:11 AM |
Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 06:06 PM |
rain guards? clips or no clips? | kylem1853 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-29-2013 01:59 PM |
Need Help... Missing Clips | NoLeftHere | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-29-2012 12:13 AM |
Aftermarket Push Button Ignition Smart Entry System | zAnSh1n | Electronics | Audio | NAV | Infotainment | 75 | 08-19-2012 02:23 PM |
