Old 06-20-2015, 01:31 PM   #1
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
KW V3 Can't Adjust Rebound
I have a set of KW V3's that I installed last night.
When I put the Rebound Clicker on the front struts, I can't turn the dial.
The dial turns fine on the back struts.
Anyone have some ideas what I should check for or adjust?
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
Old 06-20-2015, 02:25 PM   #2
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
They don't turn in either way? Sounds like you might have some dirt stopping you from turning the dial. Mine dialed fine after a bit of cleaning as they were slightly dirty. If not, contact KW or your reseller for a replacement set, because you should not have to force it to adjust, it's very easy to move
Mad1723 is offline   Reply With Quote
Old 06-20-2015, 02:42 PM   #3
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Okay, I did notice there was some kind of packaging material or something over the top of the holes. I tried blowing it out, but couldn't get it all out.
I've sent a support email to KW, I'm thinking I'm going to contact modbargains now too.
Thanks for the response
KW V3
coilovers, kw v3, rebound, struts
Compression/Rebound Adjustments amaciose Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 12-10-2014 04:51 AM
Lowering - best way to adjust camber? _frs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-28-2014 04:35 PM
Tein SRC rebound and compression set up for track mtsui Tracking / Autocross / HPDE / Drifting 13 02-27-2014 08:36 PM
