Forced Induction Turbo, Supercharger, Methanol, Nitrous |
05-26-2015, 02:59 PM | #1 |
Drives: 2013 BRZ Limited
I'm getting a supercharger! Will my car be ready?
Automatic transmission
Conclusion: for cooling with a Jackson racing supercharger I'm going with a stark automatic transmission cooler, Jackson racing oil cooler, catch can and check valve. Last edited by Byrd; 05-30-2015 at 08:13 PM. |
The Following User Says Thank You to Byrd For This Useful Post: | TheBRZsKnees (01-05-2017) |
05-26-2015, 06:39 PM | #2 |
Time Traveller
Get catch cans and oil cooler. If you end up with a lot more power, you might need more tire too and in that case, perhaps more brakes. Suspension mods not required, but are more of a nice to have at this point.
05-26-2015, 06:52 PM | #3 |
Off Topic
05-26-2015, 09:21 PM | #4 |
Yea man I meant the Jackson oil cooler
05-26-2015, 09:42 PM | #5 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Get some headers. Maybe some forged internals, better fuel pump, and larger injectors. Custom dyno tune will help, too.
05-27-2015, 05:22 AM | #6 |
Drives: 2013 BRZ limited WRB
Go jacksons. Also I think if you run e85 you will probably need bigger injectors.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
05-27-2015, 06:21 AM | #7 | |
That Guy
Drives: 2013 asphalt FRS MT
I added my .02. Take it for what it's worth. |
05-27-2015, 08:24 AM | #8 |
Drives: Toyota 86 TRD Version AT
You will also need an AT cooler for your transmission. With the added hp, the AT can get pretty hot on the track. Getting a larger radiator will also help cool down the AT and overall temps.
05-27-2015, 09:20 AM | #9 |
05-27-2015, 09:21 AM | #10 | |
Do you think a engine oil cooler and mishimoto radiator / hose / caps will be cool enough for the AT? |
05-27-2015, 09:41 AM | #11 | |
Drives: Fast
For brakes, you're spending too much money for what you're going to do. Get some good pads, stainless steel lines, and fluid, then call it a day. You don't need slotted/drilled rotors. You need a separate cooler for the transmission. The stock radiator is pretty sufficient for cooling itself. Injectors are needed if you do run e85, otherwise, they will max out with tuning and you'll leave a chunk of gains on the table. You'll also want catch cans and a check valve on the PCV side if you're running any kind of boost. Just simply getting a supercharger and hoping for the best is not the right way to do it. You need the proper supporting mods: engine oil cooler, catch cans, a really good tune, internals depending on power levels, and be ready to replace an engine if it blows or a transmission if it goes out. The Jackson kit is really solid for a daily driver and occasional track user. Stays pretty cool, and gives a nice bump in power. If you don't drive like a bat out of hell everywhere, I'm sure your engine can stay pretty reliable with it too, but the tune is the most important part of this along with a proper install. |
The Following 3 Users Say Thank You to 2016 Camaro SS For This Useful Post: |
05-27-2015, 10:10 AM | #12 | |
Thanks a lot man. I know a little of what I'm getting into but I have only started this project two months ago and it is my first car project. I'm confused on my AT and what I need to do to keep it cool with a Jrsc. I get different answers everywhere I go and everybody I ask.... |
05-27-2015, 10:33 AM | #13 | |
Off Topic
1. The engine coolant, which runs through the car's radiator. The OEM radiator is pretty nice, but you could upgrade if you wanted to. Use Subaru Blue coolant. 2. The engine oil, which doesn't have a cooler normally. This is where a JR, Perrin, or any other oil cooler would be beneficial. 3. The supercharger oil, completely separate from the engine oil. A number of kits don't have supercharger oil coolers; some do. If you're tracking your car, it helps prolong the life of your supercharger. 4. The automatic transmission fluid. Running a supercharged auto on the track is going to put some serious heat into your transmission fluid, beyond the transmission's ability to cool itself. An aftermarket cooler here would be very beneficial. |
The Following User Says Thank You to gramicci101 For This Useful Post: | Chad86 (06-06-2015) |
05-27-2015, 10:54 AM | #14 |
GET A 6 SPD! oh...wait never mind I guess I'm in the wrong thread.
Similar Threads | ||||
VORTECH SUPERCHARGER KITS!! READY TO SHIP | F-T | Forced Induction | 4 | 12-03-2013 01:00 AM |
>>>VORTECH SUPERCHARGER KIT w/ PERRIN ECUTEK TUNE ~ ONE Kit IN STOCK - Ready to ship! | Circuit Motorsports | Forced Induction | 91 | 10-24-2013 12:07 PM |
Evasive Breaks 405WHP and 306TQ on HKS Supercharger and getting ready for Pikes Peak! | Evasive Motorsports | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 34 | 09-05-2013 01:09 AM |
supercharger ready this year for FR-S? | carbonBLUE | Engine, Exhaust, Transmission | 11 | 04-04-2012 02:56 PM |
