Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
05-19-2015, 11:26 PM | #1 |
Drives: 14' FRS
Cold Start, engine makes loud pop sound
Right now I have a 2013 FRS with TRD cat back, and sometimes when I do a cold start my car sounds like gas isn't going through fully and makes popping sounds from the exhaust.
But today when I did a cold start, my god it did that a couple times, then i heard a loud pop or cracking sound from the engine noise, so i quickly turned it off and openned the hood, nothing, so I started again and it ran perfectly normal. Anyone experience this? |
05-20-2015, 10:44 AM | #2 |
You might check (or have checked) to see if the car has any stored codes.
Have you changed gas stations / gas octane lately ... ?? humfrz |
05-20-2015, 10:50 AM | #3 | |
Drives: 14' FRS
But yea I do go through a few gas stations but all same company and 91 gas all the time.
05-20-2015, 11:55 AM | #4 | |
Code readers can be relatively inexpensive to purchase. Some auto parts stores will read any stored codes for free. A stored code is one that the car stored away and can be read at a later date. My guess is that your car just "hiccupped" a couple of times and there is nothing to worry about. I hope you get it sorted out. humfrz |
05-20-2015, 07:09 PM | #5 | |
Drives: 14' FRS
Oh ICIC, kay i guess if it shows up again, ill bring it to a garage to have it checked for codes. But as of recently it has been running smoothly. No problems now. I hope they are just hiccups, but the last one was a bad one haha! |
05-20-2015, 07:21 PM | #6 | |
it seems normal car runs very rich at startup can be "tuned" out If you get pops during acceleration thats bad |
05-20-2015, 08:30 PM | #7 | |
Drives: 14' FRS
It acutally sounds similar to the first youtube video on the link. |
05-20-2015, 09:00 PM | #8 |
05-20-2015, 09:32 PM | #9 |
Mine with the TRD catback also can make some weird and wonderful noises on cold start. It always levels out and goes away as soon as it drops out of high idle so I figure it is just the nature of the beast and have never worried about it.
The Following User Says Thank You to Tcoat For This Useful Post: | Clipdat (05-21-2015) |
05-20-2015, 09:56 PM | #10 | |
Drives: 14' FRS
LMAO thats pretty good, but it also means u guys don't have the perk of snow drifting like in Canada!! |
05-20-2015, 10:32 PM | #11 | |
see tune tweaks link below High Rev Cold Start noise reduction Noisy high rev cold start is to warm up Cataylic converters for emissions purposes http://www.ft86club.com/forums/showp...6&postcount=17 Three things happen Idle is increased to 1700rpm Additional Fuel is added by offsetting MAF scale during warm-up Ignition Timing is retarded by 15 degrees during warm-up The retarded timing is what makes most of the additional noise. You may get CEL code P050B if so just disable it its due to ecu monitoring post start ignition timing. To fix alter the “Ignition Timing Post Start” table under “Ignition Timing- Advance” folder . Change all cells from -15 to -4 degrees and most of the noisy “bark” should be gone. .This image has been resized. Click this bar to view the full image. The original image is sized 1600x900.This image has been resized. Click this bar to view the full image. The original image is sized 1600x900.This image has been resized. Click this bar to view the full image. The original image is sized 1600x900. You can also reduce the “Idle control” “Idle control Target A” and “Idle control Target B” tables reduce the values for idle that are over 1400 rpm to 1400 rpm. The MAF adjustments can also be scaled back but those tables not in OFT definitions yet Don’t get to aggressive with your adjustments else your car may not idle well in very cold weather startup and you may also trigger a CEL code related to cat warmup. Whole thread on it here. http://www.ft86club.com/forums/showt...rev+cold+start |
The Following User Says Thank You to steve99 For This Useful Post: | Clipdat (05-21-2015) |
Similar Threads | ||||
Loud misfires upon cold start | connorlug | Issues | Warranty | Recalls / TSB | 42 | 03-31-2016 04:43 PM |
LOUD KNOCK during cold start | Flat_4_Life | Issues | Warranty | Recalls / TSB | 23 | 03-18-2015 05:30 PM |
Rattle sound on cold start | Frs32907 | Issues | Warranty | Recalls / TSB | 0 | 07-12-2014 10:36 AM |
rattle sound cold start | marky | Issues | Warranty | Recalls / TSB | 1 | 03-24-2014 06:16 PM |
Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 01:35 PM |
